Little Tips & Tricks :)
 1-8  9-28  29-48  49-60
8847.9 In reply to 8847.7
Hmmm...interesting thing....
Thanks Pilou!
8847.10 In reply to 8847.7
Pilou I've checked in V3.
BUT I CAN'T CONFIRM THE ISSUE!
Ok, it happens, but it happens sporadically without any prediction.
Sometimes works, sometime not. Maybe the camera angle or the rotation of the viewport makes the difference ?
I really don't know.
BUT SOMETIME WORKS SOMETIMES NOT.
TESTED.
Michael can tell us more :)
8847.11 In reply to 8847.8
Thanks a lot Metin for this tips!
Have a nice day.
8847.12 In reply to 8847.11
My pleasure, Marco!
Regards,
— Metin
visualization • pixel art • illustration • 3D design — https://metinseven.com
8847.13
in order to complete the Tips of metin
"..........If an edge exists of multiple parts, use Construct ➔ NSided."
or
select Edges > Merge > BlendCap
My Moi French Site My Gallery
8847.15 In reply to 8847.10
Hi Marco,
> TESTED.
Sorry I'm not understanding what's being tested here.
8847.16 In reply to 8847.15
Hello Michael.
I repeated the test and I've found maybe a strange behavior, but I don't know if I'm doing something wrong or not.
It's something I can't figure out.
Please check this brief video : http://take.ms/nuPqd
This is a textual explanation, but it's better to check the video.
1) I created a box 50x50x50 with a circular fillet of 10
2) I tried to "offeset" one single surface (without separate from the body)
3) AS YOU CAN SEE THE FILLET DOESN'T WORK
4) This time I created the same box 50x50x50 but with a g2 fillet of 10
5) I tried to "offeset" one single surface (without separate from the body)
6) AS YOU CAN SEE IT WORKS!
I stay tuned. Thanks.
8847.17 In reply to 8847.16
P.S. The same identical behavior happens if I use the "Inset" command.
On Circular fillet doesn't work
on G2 fillet it works.
8847.18 In reply to 8847.17
Hi Marco, that's a bug in V3 that has already been fixed in V4. The bug had to do with the fillet corners for the circular case not creating an analytic sphere surface class. When you save and reload the file it does get a specialized analytic sphere surface type for the corners and that's what makes the different behavior in v3.
According to my notes it was reported by Pilou last year through e-mail and I fixed it on May 22, 2017 so all released versions of v4 should have the fix in it.
Same thing there as well - should be fixed in v4 already.
8847.19 In reply to 8847.18
@You : "...Same thing there as well - should be fixed in v4 already..."
Perfect Michael!
Tested on V4 and it works!
I was not aware of this behavior.
Thanks and have a nice day.
Variation of the Chipp Walters Tip! ;)
8847.21 In reply to 8847.20
Very nice!
Hello everyone!
My two cents for a little Voronoi trick to get all things with filleting in two shots.
Works very well on simple Voronoi.
Check this video : http://take.ms/YNCkl
Ciao!
8847.23 In reply to 8847.22
bravo !
8847.24 In reply to 8847.23
About Voronoi :)
Just a boolean operation for inside any figure! :)
8847.26 In reply to 8847.13
Thanks for the "select Edges > Merge > BlendCap" addition, Finema. Hadn't thought of that alternative yet.
Regards,
— Metin
As a form like this can't be SuDivided directly (Top face more than 5 edges)
All Plugins by Max Smirnov
Use SSPlit for trim
Use SBridge for "Blend Faces" only 2 by 2
Use _SUbD for SubDivide
Copy / Move faces
Bridge them
Extrude to Point or Nsided (Kill the caps before) can be used for simple form :)
EDITED: 1 Mar 2018 by PILOU
8847.28 In reply to 8847.2
Hello!
SubD trials in Pilou's instructions. Tried to draw upholstery parts of a chair with SubD. It is necessary to rethink something, because the result is not yet visible when the initial form is created.
I created this one from a cuboid and used "bridge" for the "nose" in front of the seat. Then I noticed that once you split the surfaces with Split or Iso, you get points in the body that can be moved. In this way, it is possible to get closer to the desired shape and achieve the desired "upholstery effect".
Thanks for the help, you can see, it'll be all right.....
EDITED: 4 Mar 2018 by FRANZ
Size: 971 KB, Downloaded: 106 times, Dimensions: 640x360px
Size: 469.8 KB, Downloaded: 89 times, Dimensions: 640x360px
Show messages:  1-8  9-28  29-48  49-60
