Little Tips & Tricks :)
 1-9  10-29  30-49  50-60
8847.50 In reply to 8847.49
Excellent!
Never thought that the Source base curve or surface can be not "straight" or not "planar" !
Another infinite possibilities! :)
8847.51 In reply to 8847.22
Excellent :)
In 2025 Affinity is became completely free !!!
If you use the cool low price Affinity Designer (2D vectorial prog)
( less 28 € during the Covid period) less 11€ for IPad ( wishing they make the same for Android ;)
you can make directly CTRL + C , CTRL + V to Moi3D!
For the inverse Moi3D to Affinity Designer use
script: moi.geometryDatabase.copyToClipboardPDF();
Careful ClipboardAI from Moi don't works!
Put the 2 progs in A4 format for no problem of Scale !
EDITED: 10 Nov 2025 by PILOU
8847.53 In reply to 8847.52
Thanks for the clipboard tip Pilou -
I've been an Affinity Designer and Affinity Photo user for a couple of years.
At $50 each I thought they were very cheap. At $25 each, everyone should have them :)
MoI + Keyshot + Affinity are my "go to" design programs.
8847.54 In reply to 8847.53
It's of course Michael coding! ;)
Fillet don't works in one pass but yes one by one! :)
For help the "Inset" Function on objects that have been Splited by Max's "SPlit".
Just export the object, delete it, and re-import it! Make the Inset by 2 faces!
Be careful, the object cannot be subdivided directly!
It will be necessary to export it in OBJ, option "Quad + Triangles"
then use the _importOBJ by Max or the native function!
SubD / Create / From file!
Very theoretical but ultra powerful! The ISect boolean!
But don't forget also the Boolean Merge ! ;)
EDITED: 11 Mar 2023 by PILOU
Flow for make a sort of "cutting" volumes on curvated surface!
The more versatile function of Moi! ;)
More cool than LineWeb + Sweep... ;)
Moi + Banana
Show messages:  1-9  10-29  30-49  50-60
