Little Tips & Tricks :)
 1-3  4-23  24-43  44-60
8847.4 In reply to 8847.3
Thank you Pilou!
I hope that this discussion will receive many contributions.
Good idea,
Franz
8847.5 In reply to 8847.2
Hello Pilou!
+1 for your idea of this new thread !!
I'm in :)
8847.6 In reply to 8847.5
Great, I’m in
In the V3 : After a general or partial Fillet (say a on a Cube) You can't directly Shell, Inset, Offset ... a surface(s)!!! (Calcul failled)
So save and reload / Import your object! And apply the Shell, Inset...
In V4 (beta) all works fine directly! :)
(Congé = Fillet, Creux = Inset)
8847.8
Great initiative, Pilou.
Here are a few additions:
➔ In the Moi.ini file you can change an option called 'CentroidTriangulation' from n(o) to y(es). During polygon mesh export this will cause triangular faces to converge to the midpoint of ngons in stead of the boundaries of ngons, which can result in better topology, depending on your needs (e.g. a mesh that's more suitable for sculpting). A general rule of thumb is to use Centroid Triangulation when there's a higher polygon count with more uniform dicing.
➔ For a flat cap of a curved hole, trim the border edge into two halves, then bridge those edges using Loft in stead of Blend.
➔ To blend the cap of a one-part edge, use the BlendCap plug-in command (or use Trim + Blend). If an edge exists of multiple parts, use Construct ➔ NSided.
➔ If a Fillet fails on a set of edges, try to Fillet one edge after the other. You can also sweep a circle profile along the edges, Trim the result from the main solid, and Blend the naked edges.
Regards,
— Metin
visualization • pixel art • illustration • 3D design — https://metinseven.com
8847.9 In reply to 8847.7
Hmmm...interesting thing....
Thanks Pilou!
8847.10 In reply to 8847.7
Pilou I've checked in V3.
BUT I CAN'T CONFIRM THE ISSUE!
Ok, it happens, but it happens sporadically without any prediction.
Sometimes works, sometime not. Maybe the camera angle or the rotation of the viewport makes the difference ?
I really don't know.
BUT SOMETIME WORKS SOMETIMES NOT.
TESTED.
Michael can tell us more :)
8847.11 In reply to 8847.8
Thanks a lot Metin for this tips!
Have a nice day.
8847.12 In reply to 8847.11
My pleasure, Marco!
Regards,
— Metin
8847.13
in order to complete the Tips of metin
"..........If an edge exists of multiple parts, use Construct ➔ NSided."
or
select Edges > Merge > BlendCap
My Moi French Site My Gallery
8847.15 In reply to 8847.10
Hi Marco,
> TESTED.
Sorry I'm not understanding what's being tested here.
8847.16 In reply to 8847.15
Hello Michael.
I repeated the test and I've found maybe a strange behavior, but I don't know if I'm doing something wrong or not.
It's something I can't figure out.
Please check this brief video : http://take.ms/nuPqd
This is a textual explanation, but it's better to check the video.
1) I created a box 50x50x50 with a circular fillet of 10
2) I tried to "offeset" one single surface (without separate from the body)
3) AS YOU CAN SEE THE FILLET DOESN'T WORK
4) This time I created the same box 50x50x50 but with a g2 fillet of 10
5) I tried to "offeset" one single surface (without separate from the body)
6) AS YOU CAN SEE IT WORKS!
I stay tuned. Thanks.
8847.17 In reply to 8847.16
P.S. The same identical behavior happens if I use the "Inset" command.
On Circular fillet doesn't work
on G2 fillet it works.
8847.18 In reply to 8847.17
Hi Marco, that's a bug in V3 that has already been fixed in V4. The bug had to do with the fillet corners for the circular case not creating an analytic sphere surface class. When you save and reload the file it does get a specialized analytic sphere surface type for the corners and that's what makes the different behavior in v3.
According to my notes it was reported by Pilou last year through e-mail and I fixed it on May 22, 2017 so all released versions of v4 should have the fix in it.
Same thing there as well - should be fixed in v4 already.
8847.19 In reply to 8847.18
@You : "...Same thing there as well - should be fixed in v4 already..."
Perfect Michael!
Tested on V4 and it works!
I was not aware of this behavior.
Thanks and have a nice day.
Variation of the Chipp Walters Tip! ;)
8847.21 In reply to 8847.20
Very nice!
Hello everyone!
My two cents for a little Voronoi trick to get all things with filleting in two shots.
Works very well on simple Voronoi.
Check this video : http://take.ms/YNCkl
Ciao!
8847.23 In reply to 8847.22
bravo !
Show messages:  1-3  4-23  24-43  44-60
