Little Tips & Tricks :)
 1-6  7-26  27-46  47-60
As a form like this can't be SuDivided directly (Top face more than 5 edges)
All Plugins by Max Smirnov
Use SSPlit for trim
Use SBridge for "Blend Faces" only 2 by 2
Use _SUbD for SubDivide
Copy / Move faces
Bridge them
Extrude to Point or Nsided (Kill the caps before) can be used for simple form :)
EDITED: 1 Mar 2018 by PILOU
8847.28 In reply to 8847.2
Hello!
SubD trials in Pilou's instructions. Tried to draw upholstery parts of a chair with SubD. It is necessary to rethink something, because the result is not yet visible when the initial form is created.
I created this one from a cuboid and used "bridge" for the "nose" in front of the seat. Then I noticed that once you split the surfaces with Split or Iso, you get points in the body that can be moved. In this way, it is possible to get closer to the desired shape and achieve the desired "upholstery effect".
Thanks for the help, you can see, it'll be all right.....
EDITED: 4 Mar 2018 by FRANZ
Size: 971 KB, Downloaded: 106 times, Dimensions: 640x360px
Size: 469.8 KB, Downloaded: 89 times, Dimensions: 640x360px
With the new _Voronoi by Max Smirnov:)
Take 2 sets and use the ISect Boolean Function! ( whith Union Sets disabled )
then ExplodeMove hidden function
Have fun!
Here twice the same but you can take any things! :)
EDITED: 4 Mar 2018 by PILOU
8847.30 In reply to 8847.29
Cool!!
Thanks a lot for this tip.
8847.31
Wow, thank you very much for this tip.
8847.32 In reply to 8847.29
That's quite a cool technique, Pilou, thanks for sharing!
Regards,
— Metin
visualization • pixel art • illustration • 3D design — https://metinseven.com
have you seen this at ZBCentral? :-)
8847.34 In reply to 8847.33
Yep! Boozy was an old ZB artist friend of the golden age! :)
8847.35 In reply to 8847.33
Pilou and I are trying to get Boozy to hop on board over here. He's a really sympathetic chap.
Regards,
— Metin
I would love to see works from him, done with ZBrush and MoI.
Would be very interesting what he would come up with when using MoI.
BTW. Is he also "The Candy-floss Kid" from the 3DCoat Forum, because
the art style and images looks the same?
8847.37 In reply to 8847.36
<< Is he also "The Candy-floss Kid" from the 3DCoat Forum, because
Of course yes! It's the same guy! ;)
He is specialist of ZBrush, 3DCoat and seems maybe remember C4D!
It's only default : it's an Apple maniac! So missing some free true gem like Verve!
https://www.taron.de/forum/
Verve is based on Fluid's Dynamic but you can make with it any other cool things!
Like this by Knacky! ;)
or more abstract by me :)
EDITED: 6 Mar 2018 by PILOU
Thanks for the info Pilou,
much appreciated.
Hello everyone!
The great Max's Voronoi gave me an inspiration : "How to brake in two each Voronoi cell and make a funny thing" :)
You can find it at : http://moi3d.com/forum/index.php?webtag=MOI&msg=7177.107
Ciao!
Have you a trick for a Multiple NSide ?
Because repeat this on the hundred other different objects seems a little tedious! :)
Making slimy rock
3 Closed Curves
Boolean Merge (Isect can be also used but have less possibilities of choice to erase)
Fillet
EDITED: 9 Mar 2018 by PILOU
8847.42 In reply to 8847.41
Cool!! Thanks.
I usually do not deal with "3 curves" merge...Good to know!
For leaves or fish's bones, trilobites etc... :)
use the Voronoi plugin by Max Smirnov! ;)
8847.44 In reply to 8847.43
Wanderful!!!
Very nice "industrial design" made easy :)
Thanks Pilou!
So...this reinforces more and more my idea about Moi.
Moi is a CAD...but more fun than a videogame !!!!! :)
Thanks Michael!!
8847.45 In reply to 8847.41
Hi!
Pilou seduces to play.
Merge of straight polyline figures.
The remainder of the body mercilessly splintered surfaces.
SubD
That comes out.... just for fun.
Still learned something, thanks.
Franz
https://sketchfab.com/models/80e22d8e486f46939d4d2bba35d8e4ff
8847.46 In reply to 8847.29
Hi Frenchy,
how did I make the explosion?
Show messages:  1-6  7-26  27-46  47-60
