htm for Voronoi script
 1-6  7-26  27-31
8846.27
Voronoi script works good in Moi3d, but it is not easy to convert angles to rounded angles. delcorners script works too strong and make a fillet for each angle takes a lot of time. for this reasn I'm looking for a solution
8846.28 In reply to 8846.27
Hi glmr.
I've trick that works in some situation!
Check the thread "Little Tips & Tricks :)" in a few minutes.
8846.29 In reply to 8846.27
8846.30 In reply to 8846.29
thanks. sometimes it could help, but for bigger patterns it would be good to find anther way foorr smoothing angles
8846.31 In reply to 8846.29
so, I checked, thank you.
also I used explode move for make a distance between sections
Show messages:  1-6  7-26  27-31
