Move / Scale / Bounding Box Center
All  1-4  5-9
8844.5 In reply to 8844.4
Thank you both Pilou and Michael !
8844.6 In reply to 8844.3
Hi Michael, is it possible to extend this command? I would like to use one shortcut instead of two. For example, If I click a hotkey it will trigger the bounding box center, the next click will make it a normal move/scale/ command. So you can choose between these commands while using only one shortcut.
EDITED: 1 Apr 2020 by SURFERDUDE
8844.7 In reply to 8844.6
Hi surferdude,
Yes, in v4 it's possible to set up a shortcut key that will do that. Here is what you would put for the command part of the shortcut keys:
script: /* Scale, switch between center and regular */ var didcenter = false; try { didcenter = moi.command.getOption( 'scale_center' ); } catch(e){} if ( didcenter ) { moi.command.execCommand( 'Scale' ); } else { moi.command.execCommand( 'Scale BoundingBoxCenter' ); } moi.command.setOption( 'scale_center', !didcenter );
script: /* Move, switch between center and regular */ var didcenter = false; try { didcenter = moi.command.getOption( 'move_center' ); } catch(e){} if ( didcenter ) { moi.command.execCommand( 'Move' ); } else { moi.command.execCommand( 'Move BoundingBoxCenter' ); } moi.command.setOption( 'move_center', !didcenter );
8844.8 In reply to 8844.7
Amazing!
Thank you a lot! It will make my work way easier!
Patiently waiting for the final release of v4!
8844.9 In reply to 8844.8
Nice!
Show messages: All  1-4  5-9
