DOM tree of the ViewPanel
All  1  2-6
8842.2 In reply to 8842.1
Hi Anton, there is no DOM tree for the ViewPanel, it's not an HTML window. The ViewPanel and Viewports are implemented directly by MoI's own C++ code, not by WebKit.
In addition to createDialog there is also a method for moi.ui.showMenu() which shows a popup menu that will disappear when you click outside it but it's meant to be launched from a button.
8842.3 In reply to 8842.2
Oh. I see. I thought it is implemented in HTMLCanvas.
Quick look at some code that uses moi.ui.showMenu(). It's how debug popup and snaps popup work. I get it.
From what you've said i suppose this is different thing:
Just looks the same for style integrity. Right?
Thank you!
8842.4 In reply to 8842.3
Hi Anton, the menu part of the one you show there is the same thing that's created by moi.ui.showMenu(), the arrow thing that you click on is a sprite drawn in the viewport drawing code though.
8842.5 In reply to 8842.4
Thank you, Michael.
No luck for me. There are too many scripts. And using hotkeys for everything is hard. I keep forgetting them.
So i thought to implement some context menus for groups of commands.
Ok, i have another idea.
8842.6 In reply to 8842.5
Hi Anton, have you tried Max's CustomUI extension? : http://moi3d.com/forum/index.php?webtag=MOI&msg=6507.1
It adds a scripts button to the bottom command bar that pops up a menu with scripts on it.
Show messages: All  1  2-6
