Inset - Hole
All
1
2-5
mkdm
19 Feb 2018 (2 of 5)
8838.2
In reply to
8838.1
Thanks for the tip Pilou!
Ciao :)
Marco
mkdm
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Michael Gibson
19 Feb 2018 (3 of 5)
8838.3
In reply to
8838.1
Hi Pilou, you can also select the top and bottom faces and use the Shell command to make an opening like that. That way you only need to enter in wall thickness, not height.
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Finema
19 Feb 2018 (4 of 5)
8838.4
In reply to
8838.3
good tip Michael
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Frenchy Pilou (PILOU)
19 Feb 2018 (5 of 5)
8838.5
In reply to
8838.3
<< That way you only need to enter in wall thickness, not height.
But selecting 2 faces! - Inset: only one face for the same result! ;)
And with many more variations if needed! :)
Here Select only the Top's Start Cylinder Disc!
EDITED: 19 Feb 2018 by PILOU
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Reply to All
All
1
2-5
