I created 2 shapes. On one shape I CAN use EDIT/Show Pts and REshape it and on tghe other I CAN'T. Why is that? I made both shapes in the same way, with soliding ordinary lines and circles.
Hi Pozero - you can't show points for an object that is made up of multiple joined surfaces except where the surfaces share the same point structure along their common edges.
You can use Edit/Separate to break a joined object into individual surfaces, then you can show points for those independent surfaces.
