Is there a plugin script to...
All  1-5  6-9
8828.6 In reply to 8828.5
42 Karma points to you and all our Gurus (incl. Max)
Ralf:)
looking for moments of inspiration...
8828.7 In reply to 8828.1
Hi Ralf,
> Let's say i have a 10 sided polygon and i like to get a curve through all the points.
You can also use the existing Rebuild command for this task, there's an "Endpoints" mode that will build the new curve by interpolating through the endpoints of segments. There's also a "Break angle" parameter where it will keep sharp corners at lines greater than the specified angle, if you want no sharp corners preserved at all put in a high angle like 180 for that value.
8828.8 In reply to 8828.7
Hi Michael.
Thanks a lot for the reminder :)
8828.9 In reply to 8828.7
Wow this is even better..
Never used Rebuild before....
Thank you Michael to let some more light into the endless box... :-)
Ralf:)
Show messages: All  1-5  6-9
