Removing Trim/holes
 1-17  18-25
<< and i always get visible seams or even holes after i try to export that to polys. Not even join or Boolean union helped to solve that.
<< Have you tried to check your version for OBJ exporting ?
Yes and Seems not seams! :)
I made a little thickness because render don't love only simple face! :)
Always free real time SimLab Composer Lite (max 1920 * 1080)
EDITED: 15 Feb 2018 by PILOU
8827.19
Aha, i get it now how you did it Michael, you basically made 4 pizza slices and then it worked 'coz bending parts are removed. I forgot tot do that cross section trim so that's why i still had messy results.
PILOU - thanks for render test
cheers and thank you both for extra effort.
Lewis
www.ram-studio.hr
Skype - lewis3d
8827.20 In reply to 8827.18
Beatiful!
Tks.
8827.21 In reply to 8827.1
Hi Lewis,
>>I've tried recreating that surface with network
Attachment with layout for NetworkSrf (This eliminates polar uv layout)
-EDDI
8827.22
Interesting approach EDDI, does it look same from side in quad view ?
And how did you split edges/curves at exact position, by trimming or there is faster way to split curve/edge ?
Lewis
www.ram-studio.hr
Skype - lewis3d
8827.23 In reply to 8827.22
SplitHelper created with Multiiso script
http://moi3d.com/forum/index.php?webtag=MOI&msg=6841.3
Outer edge with > STRG + C > STRG + V > Join > Trim with AddTrimPoints at SplitHelper position and option keep.
Middle lines drawn with curve through points.
Result Old uv layout and new.
-EDDI
8827.24 In reply to 8827.23
Good, that now has lot more sense and I understand how you did it :).
Lewis
www.ram-studio.hr
Skype - lewis3d
8827.25 In reply to 8827.24
Wink
-EDDI
Show messages:  1-17  18-25
