how to set up the object library
 1-12  13-23
8824.13 In reply to 8824.12
Hi Subroto, are you running on Windows? Does it work ok if you start MoI up with elevated privileges? That's when you right-click on the shortcut you're launching MoI with and choose "Run as Administrator".
8824.14 In reply to 8824.13
I'm on windows and it worked with the 'Run as admin'.
Whats does that mean? and how do i enable this permanently?
Subroto
8824.15 In reply to 8824.14
Hi Subroto - there's a security measure in newer versions of Windows that prevents programs that are run at the regular privilege level from modifying the contents of the Program Files directory. That's what was preventing your object writing from working.
When you choose "Run as Administrator", that runs the program at a higher privilege level and then it's allowed to modify things in Program Files.
You can enable it permanently by right-clicking on that shortcut and choosing "Properties". Then on that properties dialog go to the Compatibility tab and near the bottom there's a "Privilege Level" section with a checkbox for "Run this program as an administrator". If you set that then it will run like that by default.
I think Max has an updated version of CustomUI for version 4 which moves these things over into the AppData folder which does not require elevated privileges.
8824.16
Hi all.
If you go to [MoI installation folder]\ui\customui\mods and edit ObjLibrary.cfg you'll be able to type in new path.
Format:
[NAME that will appear in the UI for that library][COMMA or SEMICOLON][PATH in quotes]
Example from my ObjLibrary.cfg:
Object Library;"D:\OneDrive\nurbs\objlib"
Also you can have multiple object libraries. And they will be separated by line in UI. I believe for new entry you also need to separate it with comma or semicolon.
All above is true for MoI v3.
And yes, you have to edit ObjLibrary.cfg with administrator privileges. So in win search you type 'notepad' (or any other text-editor of your choice). Click on it with right mouse button. Choose 'Run as Administrator'. Then in notepad you open ObjLibrary.cfg, edit it and save it.
8824.17
Thanks to both of you.
I'm currently runnin as admin, and its working fine.
I will try what Anton suggested too.
8824.18
Hello guys anyone please can help when I try to add object from my object library the pivot point for the object in difrint place not in the object center anyone have idea why? Thank you in advance
Size: 28.9 KB, Downloaded: 120 times, Dimensions: 788x496px
8824.19 In reply to 8824.18
Load object, set a cplane, and re-save?
8824.20 In reply to 8824.19
Thank you bemfarmer.
8824.21 In reply to 8824.10
Hi MOI users, I am having the same problem where the object folder won't let me add anything to it. I had a bit of a struggle just getting the Custom UI to work. So I am trying to figure out what I did wrong. In reading this post on. How to set up the object library. Sure sounds like I un-zipped the file one layer to deep. Wonder if anyone could explain what I should do. I read this post over and over. But just wanted to see if anyone could steer me in the right direction. Thank you for any tips.
8824.22 In reply to 8824.21
Hi Specktech, can you show a screenshot of the directory structure that you've set up?
Also what operating system are you running on?
8824.23 In reply to 8824.21
Try running MoI as Admin.
Show messages:  1-12  13-23
