Auto-retopology algorithms compared
 1-3  4-23  24-43  44-63  64-65
Hi Metin,
if you like to check out an alternative to Instant Meshes you should take a look at
QuadriFlow. It is a CLI Tool and slower than Instant Meshes, but it produces meshes
with very litte singularities, compared to Instant Meshes.
https://github.com/hjwdzh/QuadriFlow
EDITED: 27 Aug 2018 by STEFAN
Hi Metin,
i think this is most interesting when it comes to NURBS conversion, after auto-retopo...
I did a quick test and re-meshed the bunny with QuadriFlow and i think also with a higher
resolution and now after converting with Fusion360 i have much fewer patches than with
my old NURBS bunny and also more definition in the NURBS surface... :-)
I think i must do a better comparison again, with creating new bunny meshes and then
converting, to get a better picture, but i strongly believe it has to do with the fewer
singularities QuadriFlow produces.
The left bunny in my picture has 183 surfaces, while the right bunny has only 112! :-)
Bildschirmfoto_2018-08-27_um_23.37.46
8817.6 In reply to 8817.5
Hi Stefan,
Many thanks for this very interesting tip, much appreciated! I hadn't heard of Quadriflow yet. It looks very promising.
You're a macOS user like I am, or am I mistaking? Do you know how to get this to work in the Terminal? Too bad there isn't a GUI (yet).
Regards,
— Metin
visualization • illustration • animation • 3D design — metinseven.nl
8817.7
Michael, this could be an interesting algorithm to implement in Moi, don't you think?
It could be used for conversion of polygons to NURBS:
1: First offering the algorithm for retopology after polygon mesh import.
2: Then offering the option of polygon subdivision inside MoI.
And it would be great for mesh export topology as well.
Regards,
Metin
visualization • pixel art • illustration • animation • 3D design — https://metinseven.nl
Does Quadriflow a "Line text command" program ?
My Moi French Site My Gallery
8817.9 In reply to 8817.8
Yes, looking at the page's instructions, it's a command line tool at the moment. I'm a reasonable Terminal noob on the Mac, so I'd love to see detailed instructions how I could install and use this.
Thanks!
Regards,
— Metin
Hi Metin and Pilou,
you need Developer Tools (C compiler and CMake) to compile the program and the you need also the
listed dependencies compiled, in order to use the program. And yes, Pilou it is a command line program.
8817.11 In reply to 8817.7
Hi Metin,
Well it's a polygon modeling operation that inputs polygons and output polygons, so it's probably not a great fit for MoI currently with MoI having no polygon modeling functionality in it.
8817.12
Hi all,
I like to add to this discussion on re-topology "Instant Field Aligned Meshes".....
"....The software converts geometry to uniform quad or triangle meshes, automatically following the curvature of the geometry and snapping edges to sharp features on the model."...etc
http://www.cgchannel.com/2015/11/download-free-auto-retopology-tool-instant-meshes/
http://igl.ethz.ch/projects/instant-meshes/
https://www.foundry.com/trends/design-visualisation/mitsuba-renderer-instant-meshes
regards
O.
Hi Metin,
to give you a better overview what to do... first install Apple's Developer Tools and it' command line utilities + CMake.
Once done install a package manager like MacPorts or Homebrew, to install the listed dependencies.
After that you simply follow the steps outlined on the Github page to download/compile and use the program.
Hope this helps.
Hi Ken,
the link you give refers to Instant Meshes, which Mentin and i have mentioned.
Instant Meshes however creates more singularities in polygon meshes than
QuadriFlow, hence the reason why i posted this.
8817.15 In reply to 8817.14
Hi Stefan,
many thanks for clarifying this issue and apologies for being late !
best wishes
Ken
8817.16 In reply to 8817.13
Thanks Stefan!
I'm afraid this is a bit too much hassle for me. I've always avoided going the Homebrew route. Back in the good ol' Amiga days I loved to dive deep into such things. Nowadays I've developed enough patience to wait for an easily usable implementation, without hacks and workarounds. :)
But I'm eager to use it as soon as there's a GUI or integration, maybe into Blender. I've started a topic at the Blender Artists forum about it:
https://blenderartists.org/t/new-quad-auto-retopology-algorithm/1124406
If you respond to the thread, it will be bumped up to the top of the thread list again. ;)
Regards,
— Metin
8817.17 In reply to 8817.11
OK. I thought it could be an ideal algorithm to implement with regard to your plans for polygon to NURBS conversion inside MoI.
I was thinking of an import dialog offering to retopologize an imported polygon mesh using the algorithm, and add the option of subdivision like in the tools by Max, comparable to Stefan's bunny test.
On the other side, the algorithm could offer perfect quad-poly topology output inside the mesh export dialog, ready for subdivision in a polygon-based 3D editor.
Regards,
— Metin
8817.18 In reply to 8817.17
Hi Metin, from a quick glance it looks like it's more oriented towards processing organic shapes. I'm not sure what would happen if you tried to feed it a CAD model with a mixture of large and small features in it.
8817.19 In reply to 8817.18
Good point, Michael.
Looking at the Siggraph paper...
http://stanford.edu/%7Ejingweih/papers/quadriflow/quadriflow.pdf
... the algorithm includes a sharp edge detection feature:
Regards,
— Metin
Hi Metin,
I understand. ;-) Maybe this topic should be posted at the 3D Coat forum, because
i think they have also Instant Meshes now included in the latest beta(s) of 3D Coat.
Maybe Andrew is faster than the Blender folks?!
8817.21 In reply to 8817.20
Good suggestion, Stefan, thanks. I'm going to post it at the 3D-Coat forum as well.
Regards,
— Metin
8817.22 In reply to 8817.19
Hi Metin,
Yes that probably helps some CAD models from just being completely destroyed but I'd think that having a uniform size output is not going to work well with many mechanical objects.
It would be good to see the result on something like this for example:
https://grabcad.com/library/engine-v-twin-4-valve-heads-1
In the paper there is one screenshot of a motorcycle that was converted and it looks pretty weird to me, many areas are mutated pretty significantly.
This isn't to say at all that it's not a useful tool when used where it is intended.
8817.23 In reply to 8817.19
Hi Metin, I've attached an example CAD model here (taken from https://grabcad.com/library/ngoc-mai-tug-boat-1), it would be interesting to see what the output is on these:
Show messages:  1-3  4-23  24-43  44-63  64-65
