Drawing a shape, but how?
 1-12  13-32  33-52  53-72  73-81
8815.53 In reply to 8815.52
Does JD Paint has also a free version ?
My Moi French Site My Gallery
8815.54 In reply to 8815.53
@You : "...Does JD Paint has also a free version ?..."
C'mon Pilou! :) Let's spend two cents for a software one day !!
LOL :) :)
I'm kidding of course :) :)
No, and i think since ArtForm is it's successor you can no longer buy JDPaint from their site.
But ArtForm is almost the same as JDPaint.
And then there is also JDSolid, but i think this is also not free.
Would be interesting to see JDSolid in action...
https://translate.google.de/translate?sl=zh-CN&tl=en&js=y&prev=_t&hl=de&ie=UTF-8&u=http%3A%2F%2Fbbs.jingdiaosoft.com%2Fforum.php%3Fmod%3Dviewthread%26tid%3D5310%26extra%3Dpage%253D1&edit-text=
Thx for the precisions and informations! :)
8815.58 In reply to 8815.51
Wow Pilou, great!
Imagine after drawing anything perfect with MOI, and after merging sufaces with ArtForm.
Will be excellent smooth.
Franz
EDITED: 14 Feb 2018 by FRANZ
8815.59
Friends of Nurbs!
Different possibilities to draw a basically simple shape with different curves did not let me go.
I also tried the procedure with SubD. Unfortunately, however, I always came up with an uncontrollable result.
Finally, however, I found an additional quick and well controllable possibility, which delivered a clear result.
Have a nice day,
Franz
My attempts with SubD:
8815.60 In reply to 8815.59
Hi Franz.
@You : "...I also tried the procedure with SubD. Unfortunately, however, I always came up with an uncontrollable result...."
Hmm....this sounds a bit strange...
The good thing about SubD is that you can always leverage on supporting edges placed near of far the main edge loops to control the sharpness of the curvature.
But this is much easier if you do SubD things using a "true" SubD modeler. Moi + Max's SubDiv plugin is great but has a lot of limitation because Moi is Nurbs, SubDiv not :)
Of course it's not the same thing like dealing with true Class-A surface tools but...
Ciao!
Why not try my first little tricks ?
Seems you can control all that you want! :)
And it's pure Nurbs!
http://moi3d.com/forum/index.php?webtag=MOI&msg=8847.1
PS That works also on SUbD result! ;)
EDITED: 26 Feb 2018 by PILOU
8815.62 In reply to 8815.59
Hi Franz,
you have more control with your model if you can add more edge loops.
Max's split command, for his subd script, does this.
8815.63 In reply to 8815.62
Thank you, stefan.
I may just need to understand what is really important when using SubD. I will try again....
Best regards
Franz
8815.64 In reply to 8815.63
Hello Franz!
@You : "...I may just need to understand what is really important when using SubD...."
Simple....two things :
1) Create only quad polygons and a very few triangles. No polygons that has more than 4 edges if you really want good results.
Ok, if you know that some particular area of the object will not be framed by the camera then you can do what you for with that area,
but if something has to be viewed by the camera and/or close to it you must have quads if you want good results when subdiv.
2) Create edge loops only where you need it.
But these two points are not simple. You need years of experience :)
Ciao!
Marco (mkdm)
If that can help :)
As a form like this can't be SuDivided directly (Top face more than 5 edges)
Use SSPlit for trim
Use SBridge for "Blend Faces" only 2 by 2
Use _SUbD for SubDivide
Copy / Move faces
Bridge them
Extrude to Point or Nsided (kill the caps before) can be used for simple form :)
EDITED: 1 Mar 2018 by PILOU
8815.66 In reply to 8815.65
Thank You all!
Valuable tips. I tried a little bit and got closer to the goal.
I have another question. With SSplit it doesn't work with create and move position with one point.
The position of the split edge can only be adjusted with the slider.
How do you do it, Pilou?
Regards from
Franz
EDITED: 1 Mar 2018 by FRANZ
8815.67 In reply to 8815.66
<< How do you do it, Pilou?
I have not your Box Dialog for this sort of "trim" section segment wanted! :)
I have just a ShortCut "P" for the plugin _SSplit of Max Smirnov
http://moi3d.com/forum/index.php?webtag=MOI&msg=6674.254
So on a rectangular box (as shown on the video)
Function call a Face(s) or a segment...so
I click on a segment (so pre-selection) then Press "P"
For a vertical "trim" select an horizontal segment and you can move your vertical "section"!
Select a segment etc...
Of course if you want an horizontal "trim" select a vertical segment and move your horizontal "section" ! :)
Of course after one apply section you can just select a segment and Richt Click (recall last function) or Press "P" as yo want!
You must "bridged" faces for have this subdivided volume! If you make extrude you will have separated subdivided volumes!
PS If you select a Face I have your Box Dialog for input quadrangular faces on the selected face(s)!
I don't know if "trim section" is the good words ... "subdivided section" ? ...
8815.68 In reply to 8815.67
Hi Pilou!
I had an old version from sSplit, now I updated.
Thanks for the link, Franz
8815.69 In reply to 8815.68
These plugins (SSplit, SBridge, SSCale, SubD ) is a true gem! :)
Bravo to MAX !
Just if "snap" during the move of the segment section will existing that will be gorgeous! But not vital for organic volumes! :)
8815.70 In reply to 8815.69
Hi Pilou!
I tried to insert the older version sSplit. v. 0.6.2015.03.26 with a renaming to sSplit_old next to the new version.
But only the newer version works, maybe something would have to be changed in the files sSplit_old. The old version would have the additional effect that you could work with equal values for a cube (10,90 or 30,70) to get a symmetry.
(Because of missing snaps).
We can't thank Max enough, I agree.
This forum is full of extraordinary people.
Franz
8815.71 In reply to 8815.70
Seems I use also the last version of 2015 ;)
http://moi.maxsm.net/files/scripts/sSplit.v.0.95.2015.08.10.zip
8815.72 In reply to 8815.71
Hi Pilou!
Before I have not seen the counter, so I can also reach symmetry.
That's actually enough.
Thanks for the tip with the points shift, it is getting better and more controllable. Great!
Franz
Show messages:  1-12  13-32  33-52  53-72  73-81
