Drawing a shape, but how?
 1-7  8-27  28-47  48-67  68-81
8815.28 In reply to 8815.26
And at the last page register (if success) what button to Press at the end ?
Edit success register but now
EDITED: 13 Feb 2018 by PILOU
it should be the little blue button below the Captcha code. The other two buttons, the big blue and big green are for other network media registration, if i remember correctly. Like QQ (large blue button) a chinese service, similar when you register at sites via a Facebook account.
@Franz currently i can't help because i'm busy at work, but it looks like you have not merged the corners. I did it that way that i merged the corners with their sides first and then merged the other sides with the top surfaces and at the end merged those large stripes as one surface.
8815.30 In reply to 8815.29
Registering : success! :)
<< Once you have access to the forum (the original Chinese page) and downloaded the
software
what button for Download the prog ? :)
like i said before you have to carefully read Chris posting (click the link)... There you will find at the first posting at the bottom a login and download link.
Hope this helps.
8815.32 In reply to 8815.1
Hi Franz,
this technic may give you what you want.
I joined your curves and ran the rebuild command on them.
Networked the top face. Extruded the base shape with no caps.
Blended the top to the bottom with a 1.2 bulge.
Blend corner blend to blend not base.
Joined all and ran planar to cap bottom.
Hope this helps.
Barry
I am connected on the forum (as shown by the little guy right to the white ring bell)
but when i click the Blue button of download with white Arrow the same page is back again!
Same result on these 2 pages! So what is your secret ? :)
8815.34 In reply to 8815.33
Hallo Pilou!
I think I have done on the first one. May be I choosed the text with ArtForm3.5, dont know exactly.
But at the moment I can't make a login myself, because I don't know about the security question.
I dont remeber to give any security answer while I registered.
Unfortunately you can't copy the text, so I tried it with a text recognition program from the image.
But unfortunately no success, because I don't know my security question, I am sorry.
http://www.i2ocr.com/free-online-chinese-simplified-ocr
Hi Franz and Pilou,
sorry that i cant be of assistance. I downloaded it long time ago and it seems that the procedure
may have changed a bit. At least i never had security questions, only the Captcha thing with the
two chinese characters in the past, but this might have changed too?
Seems the security question is optionnal because that don't block your login to the forum !
My Moi French Site My Gallery
8815.37 In reply to 8815.35
Thanks Stefan, it's just the weird letters...
Well, if you've managed to be in the forum,
then press the text JDsoftArtForum 3.5 under the download button.
Then you get to the download page, just scroll down to the bottom and download....
Here some screeshots:
8815.38 In reply to 8815.37
A long run race! :)
Wishing now that the 2 parts unzip well :)
Of course there was a last trap!
be carreful!!!
The install program don't build a name folder so all folders / files go directly in the Programms file folder
so a new mess! :)
8815.39 In reply to 8815.38
Launching the prog i have that! :)
Seems my tribulations are not finished! :)
Edit : That Work : input User Name / Password of the Forum register! ;)
My first chiness thing! :)
and now new headache for export that! :)
8815.40 In reply to 8815.39
Hi Pilou!
Look at this:
8815.23
and the answer of stefan.
Have fun!
... now I also have found the correct entry of login ...
EDITED: 13 Feb 2018 by FRANZ
Size: 93.4 KB, Downloaded: 60 times, Dimensions: 1244x700px
8815.41 In reply to 8815.40
Yes I found the trick in the previous minutes! :)
Now the hunting convert files 3D is open! :)
Seems all is built on a plan ?
So a tore is an half tore! (?)
Seems vs3d format is the best way! :)
ArtForm Pro has four modules (or rooms) you can work in.
You are currently in the first. If you go to the third module/room
you have access to ArtForm's Surface NURBS modeler were you can
import .3dm files from MoI or export from there as .iges.
The other modules are used for drawing, like in Illustrator or
for sculpting 2.5D reliefs. The fourth module is for setting up
paths for CNC machining etc.
If you want to learn sculpting 2.5D reliefs i suggest you look
at Youtube videos about JDPaint. ArtForm is the successor
of JDPaint and is compatible.
8815.43 In reply to 8815.42
Seeing speedy the video this morning i have believed that was separated progs! :)
Cool that all is inside! :)
So no problem of export to Moi or import! :)
8815.44 In reply to 8815.32
Hi Barry!
Now I have really reached a satisfactory point, and all this in Moi!
The model was almost unchanged and still a seamless shape.
To get a body, I deleted the yellow surface afterwards and made a network (evenly) with the edges.
Then a solid connection could be made.
Thank you for your support!
Franz
8815.45 In reply to 8815.42
Thank You Stefan, for the tipp with the chinese innovation.
May be also interresting to prefaere drawings for working on CNC machines.
And now have a little more carnival experience....
Franz,
with best regards to all
8815.46
Hello,
Loft and Blend is one method. I should have some time for a video if needed.
Does Artform has some notions of History ?
Show messages:  1-7  8-27  28-47  48-67  68-81
