V4 beta Feb-9-2018 available now
 1-11  …  92-111  112-131  132-151  152-163
8814.132 In reply to 8814.130
For little part of screen (for not big files result to send on the Net) you have little free true gem!
GifCAM
http://blog.bahraniapps.com/gifcam/
8814.133 In reply to 8814.128
The reluctance of the little popup window to appear also occurs on my Windows7, with wireless logitech mouse. Nice keyboard mouse combo, MK735, from Costco.
(Same reluctance with USB wired mouse.)
EDITED: 31 Mar 2018 by BEMFARMER
8814.134 In reply to 8814.133
Sounds like this might be a different bug? The problem that Vladimir is showing in that video is that the mouse cursor isn't changing to the "text field" I-beam shape.
Could you please give a little more description of what you're seeing?
Is the "little popup window" you're talking about the "Edit size" one that normally shows up when you click on the size line in the properties panel?
8814.135 In reply to 8814.134
In MoI4FebBeta: Select a line. In the upper right of the screen, left or right click on the Length field, (not on cm). The Edit box appears. So far everything is OK.
Right clicking in the Edit box only occasionally brings up the box with (cut/copy/paste/delete/select all) (Which I guess are Windows7 commands.)
(Similar result for circle or ellipse Edit box.)
In MoI3 Right clicking in the Edit box brings up the cut/copy/... box right away.
(I do get the I-beam shape OK.)
8814.136 In reply to 8814.135
Hi Brian, yup I can reproduce yours over here - thanks for the additional details! I will investigate it.
I can also get part of what Vladimir showed which is the Cut/Copy/Paste context menu shows even when clicking slightly outside the edit field.
8814.137 In reply to 8814.131
Hi, Michael.
> I use Camtasia by TechSmith for doing screen captures
I meant the appearance of the context menu when clicking right mouse button, but in the study delineated the problem of the change of kosora. This problem is not stable and is rare. All this is not critical and you can work.
Michael I have a request for you. A small lesson or a link to such a lesson as insert video GIF animation with start / stop buttons. I do not insist, and sorry to distract from the Affairs of this request.
Vladimir.
8814.138 In reply to 8814.137
Hi Vladimir, thanks for the additional information. I will investigate that, it appears that particular kind of text field is having mouse coordinates offset when in a flyout menu.
Usually the way I do it with Camtasia is after the video is uploaded, it displays a dialog that contains some "embed code" which is some HTML you can paste into your message here and then the player controls will show up.
I don't think there is any automatic way to make a web browser show start/stop controls for an animated .gif . There may be for a .mp4 video file though.
8814.139
i have a problem, which has kind of stopped me from using moi on my Macbook pro, which I thought would be because of the low performance. yesterday I bought my new iMac pro but
iam having the same problems still. whenever I navigate in my scene, the video performance is very choppy, which makes it hard for me to concentrate on modeling. my old z820 with windows 10 doesn't show that problem at all...
https://youtu.be/wrELYeBlO-8
cheers from cologne
torsten
8814.140 In reply to 8814.139
Hi torsten, do you mean a kind of "tearing" effect? I'll see about putting in an option to limit the display to the display refresh and see if that helps.
8814.141 In reply to 8814.140
yes that effect... please it would really help me.... :-)
cheers
torsten
8814.142 In reply to 8814.141
Hi torsten, does it also happen in MoI v3 or does it behave differently between v4 and v3 ?
8814.143 In reply to 8814.142
in moi 3 everything seems to be somehow slower as if the machine can only produce a limited amount of frames per sec.
moi 3.2:
https://youtu.be/AwO48IAN5HQ
cheers
t.
8814.144 In reply to 8814.143
Hi torsten, so no tearing in v3 though? Is that preferable for you to have it slower and no tearing rather than faster with tearing?
8814.145 In reply to 8814.144
the tearing drives me more crazy, but why does anything have to be "slow" on the newest machine money can buy :-(
cheers
t.
8814.146 In reply to 8814.145
Hi torsten,
I think it's related to the huge increase in display density.
I do have some other tune ups for the next v4 release that were impacting display speed in some situations on newer iMac pros so hopefully that will help.
8814.147 In reply to 8814.146
there is an option where I can choose to run the app in low resolution, but this also doesn't change things...
i am looking forward to the next release :-)
cheers
t.
8814.148 In reply to 8814.147
Hi
I haven't "slow" on Mac (Retina 5K, 27 pouces, fin 2015)
it' only on Imac Pro ?
8814.149 In reply to 8814.148
Hi Finema, what video card do you have on your Retina Mac? It seems the issue is with certain nVidia cards having some kind of penalty when rapidly switching between 3D and 2D GUI drawing. But the next v4 beta should improve this.
8814.150 In reply to 8814.149
i have :
AMD Radeon R9 M395X 4096 Mo and it's very fast and fluid on MoI V4
Message 8814.151 deleted 9 Apr 2018 by BEMFARMER
Show messages:  1-11  …  72-91  92-111  112-131  132-151  152-163
