Export to DWG
 1-8  9-28  29-33
8780.9 In reply to 8780.8
Would you consider Teigha libraries for dwg support?
8780.10 In reply to 8780.9
Hi flim,
> Would you consider Tiegha libraries for dwg support?
The last time I checked they were pretty expensive, and their base level licensing for commercial products only allowed distributing 100 licenses which seemed pretty weird so it didn't seem like it would work for me.
It would make sense to license it if DWG support was a really core central focus of the product (like for an AutoCAD "replacement") but for MoI that isn't the case.
since the OP does not reply to our suggestions, i tried it myself.
Because MoI exports .dxf as 2D drawings one has to use free
Software like Autodesk 123D Design or Inventor Fusion etc.
MoI = .step -> Autodesk 123D Design = .DWG -> BricsCAD ;-)
And I believe that free https://www.turbocad.com/content/doublecad-xt-v5
can also make the trick! ;)
Worked fine also for SketchUp! ;)
8780.13 In reply to 8780.11
Hi Stefan,
Thank you for suggestion. However 123D is no longer available now.
Not sure about DoubleCAD as it is 2D only I think.
Frederick
8780.14 In reply to 8780.13
Hi Frederick,
yes, it is discontinued. But the Windows version is still available at Softpedia.
http://www.softpedia.com/get/Science-CAD/Autodesk-123D.shtml
8780.15 In reply to 8780.13
Or Autodesk Fusion 360 might work for that purpose.
8780.16 In reply to 8780.14
Hi Stefan,
Thanks. I will check it out.
Regards,
Frederick
8780.17 In reply to 8780.15
To convert format it must upload to A360 cloud and download another format via email link. Very inconvenient.
Regards,
Frederick
8780.18 In reply to 8780.13
<< It's only 2D (Double CAD)
I used it like this :)
Import format skp (3D) inside Doublecadxt (free) export as DXF 2000 2003 for Blender (3D)
Sorry I can't test it anymore because i have not more it!
EDITED: 11 Jan 2018 by PILOU
Having never used BricsCAD, it appears that:
ACIS solids (.SAT) CAN be imported, by typing the ACISIN command, (without communicator.) (???)
Please see the next two links:
https://forum.bricsys.com/discussion/23380/acis-import-and-export-no-longer-supported-under-v14-without-communicator (FALSE)
https://forum.bricsys.com/discussion/18131/supported-import-format
.....Bricscad can also import/export ACIS solids (.SAT) via the ACISIN and ACISOUT commands. There are also third part opti.....
A free manual:
https://www.bricsys.com/bricscad/docs/en_INTL/V18/BricsCAD-V18-for-AutoCAD-Users.pdf (Page153-156)
SYCODE had an import addin for versions 8,9,10, but was acquired by 3DSystems, (and seems to have disappeared?)
But i refound that! (with the complicity of Patrick ;)
so cost = 0 $ except for Autocad & Moi if more than simple export DWG needed on another process wanted! :)
SketchUp Make free on local computer is now only SketchUp Make 2017 : https://www.sketchup.com/download/all/
(Moi export) --> Format Skp --> DoubleCad -->DWG ---> Autocad (Briscad etc...
(take export SKP V 8 for more compatibility)
So can be directly Moi --> DoubleCad --> AutoCad etc... :)
i can confirm ACIS support. I looked at the trial (Platinum Edition) and under the Insert Menu
one can import / export .sat files from or to MoI! :-)
8780.22
There is also ViaCad, which is relatively inexpensive and can serve as a converter.
Older versions can be found for cheaper on amazon.
Marc
8780.23 In reply to 8780.20
.skp format can only contain polygon meshes, so you won't get a transfer of the original CAD solids and surfaces if you use this method.
8780.24 In reply to 8780.17
Hi Frederick
.sat format by the ACISIN/ACISOUT or insert menu item as described above should be the way to go.
For importing into MoI you may need to use an option to make older version of .sat like v8 format so that it generates regular NURBS surfaces and not specialized ACIS surface types in the generated .sat file.
8780.25 In reply to 8780.23
Don't know what is the final objective... so it was just a method! :)
My Moi French Site My Gallery
8780.26 In reply to 8780.19
Good found. Thanks a lot!
I confirm that I can use ACISIN command in BricsCAD, and import model export from MoI.
Thanks all for help.
Fredeick
8780.27 In reply to 8780.26
Hi Fredeick,
Thanks to STEFAN, Michael, and yourself for checking it out, and their knowledge.
8780.28
I have BricsCAD Mechanical v19, Rhino 6, I just bought MoI because I like the interface very much and would like to use it more.
I really hope MoI support DWG format, it is really helpful when communicate with vendors using AutoCAD, because DWG has layer. I am not only export 3D solid, but other data like the sketches.
If I export to other format the layer information are lost.
My supplier give me the DWG and I can open it in Rhino, I made changes and save it as DWG and send to them. If I want to use MoI I have to use Rhino to open the DWG then save as 3dm for MoI, make changes in MoI, I open the drawing in Rhino and save it back to DWG.
Size: 989.5 KB, Downloaded: 58 times, Dimensions: 2560x1080px
Show messages:  1-8  9-28  29-33
