Hów to ?! > Rail Array
All  1-10  11-17
8762.11
I think a way to go will be to create a zigzagged edged curve to embed the gems which
follows the contour of the original curve.
There is an ArrayGem script.
- B
8762.13 In reply to 8762.12
I have tried it for my purpose but did work as I expected, will have a look again.
8762.14 In reply to 8762.13
Hi Tom,
I used the array gem command to get the following result.
I lofted between your 2 curves to give a surface.
Produced a curve in the middle of your 2 curves using the iso tool .
Added a base diameter to your gem and then ran the script.
Hope this helps.
Barry
Size: 175 KB, Downloaded: 88 times, Dimensions: 800x700px
8762.15 In reply to 8762.14
Looks awesome - possible I made a mistake when I tried out the arraygem !
8762.16 In reply to 8762.15
Hi
Same result here
I join the 3dm file
EDITED: 28 Jul 2018 by FINEMA
8762.17 In reply to 8762.16
Thank you for adding your file, Finema - great !
EDITED: 4 Jan 2018 by SIRTOM
Show messages: All  1-10  11-17
