Curvy corner help
All  1-2  3-5
Hi Sascha,
i would try something like this.
Draw a rectangle in the top view, fillet the corners and then extrude the rectangle.
After that draw a side profile and then do a boolean diff with it.
Once you have a similar shape like shown in my picture (the remaining grey part)
fillet it again with the smaller fillets. Well just a thought.
Size: 329.4 KB, Downloaded: 48 times, Dimensions: 800x584px
Hi Sascha,
o.k. i used your model as guide, to obtain your models dimensions and then applied
the technique which i described previously. For the large corner fillet i used a radius
of 1 and for the small fillets i used a radius of 0,05 (G2). Hope this helps.
8759.5 In reply to 8759.4
Wow, thank you guys. Both works for me! Meanwhile I played around and found a third solution - but not as smooth as yours - I did an extrusion with path. Maybe I can achieve my goal with that method, too. But finally I used Stefans way as fastest and best working for me.
Thanks again.
Size: 16.6 KB, Downloaded: 27 times, Dimensions: 515x404px
Size: 17.1 KB, Downloaded: 25 times, Dimensions: 562x376px
Show messages: All  1-2  3-5
