i need help
 1-3  4-23  24-33
8754.4 In reply to 8754.3
Hi Max, a lot of categories can only help if everyone is guaranteed to use them which just doesn't happen. Probably just a couple of categories would work but I'm focused on working on v4 right now so that will have to wait.
8754.5 In reply to 8754.2
i install this but there a lot of errors
i use win 10
8754.6 In reply to 8754.5
You'll need to give some screenshots of the errors for anybody to have a chance at helping you.
8754.7 In reply to 8754.5
Did you see that it will not work properly with the V4 beta...?
But like Michael said if you try to install it on V3 -> send some screenshots of the errors
Ralf:)
looking for moments of inspiration...
8754.8 In reply to 8754.7
in obj library i have only cube sphere and surface, i dont have cyilider, nut , gear, bearing etc..
ext. scripts i have only 10 scripts.. but on this picture have a lot of scripts.. how can i get all scripts http://moi3d.com/forum/get_attachment.php?webtag=MOI&hash=e4c39275ea2a413c3150005655276712&filename=scripts02.png&inline
snapshot work..
lighting dont work
when i install CustomUI.1.0.mac.zip i get errors
8754.9 In reply to 8754.8
Have a look here: http://moi3d.com/resources
There you find some links to Petr's MoI page, and Max Smirnov's MoI scripts
I thought you are on Windows... the CustomUI.1.0.mac.zip is for Mac
Ralf:)
8754.10 In reply to 8754.9
ok thank u..i will check
this is my project in moi 3d
Size: 458.5 KB, Downloaded: 154 times, Dimensions: 1043x793px
Size: 507.1 KB, Downloaded: 85 times, Dimensions: 1192x830px
8754.11 In reply to 8754.10
Cool tractor 4rw1n.
What is the make and model/ year?
A lot of help already exist in the forum, and many will respond to specific help requests.
8754.12 In reply to 8754.11
this is replica of ferguson, named "imt 539"
For 2 days, with pain, I try to make a real hub from a tractor .. but I cannot handle it .. Im not happy..
https://s6.pik.ba/galerija/2016-10/01/08/slika-172584-57ef572fc9a97-default.jpg
8754.13 In reply to 8754.12
Hi4rw1n,
We used to have a MF 135.
I would call that metal cover a "hood," or an engine "cowl."
Do you have photographs taken at 90 degree angles? And dimensions?
Front view, side view, top view? If so you can load the images into MoI, with View Image, and then make 2D profile curves.
Others have posted on the forum about starting with say a rectangular cube, and Trimming or Boolean difference, away parts of the cube,
and then doing Fillets. So it is a subtractive process.
It seems that most photographs are taken with the machine at an angle, but there are a few front view out there.
8754.14 In reply to 8754.13
i have 2 picture, and from this 2 pictures i make hoot but not good.. i try find blueprints of MF 135, but dont have
so i really dont understand how to make hood, i make but this not perfect if u can help here is my project u only show how to make better..
project file https://files.fm/f/x77kpk6r
why this happen all is ok in cinema 4d and Moi#D but in Substance Painter get something wrong
see Cinema 4D and Moi#d is ok
https://imgur.com/a/eox2q
https://imgur.com/a/6lppp
and here is Substance painter , problem
https://imgur.com/bKfxLOK
8754.15 In reply to 8754.14
Hi 4rw1n, probably Substance painter doesn't like to deal with complex n-gons. When you do the export out from MoI try using the "Output: Quads & Triangles" option instead of "Output: n-gons" and see if that works better.
8754.16 In reply to 8754.15
thank u michael, its working!
8754.17
heloo.. that i dont open new topic i will write here..
i have problem, my english not good but i will try explain..
when i make some object and use tranform mirror after that i get 2 object same its ok.. but when i mark only 1 that object and rotate also another object rotate, i want only one rotate..
8754.18 In reply to 8754.17
Hi 4rw1n,
Sounds like past History is associating the mirror copy with the original.
I think the History command can break the "connection."
http://moi3d.com/forum/index.php?webtag=MOI&msg=8475.2
http://moi3d.com/forum/index.php?webtag=MOI&msg=7940.1
EDITED: 13 Jan 2018 by BEMFARMER
8754.19 In reply to 8754.18
its work.. thank u!
8754.20 In reply to 8754.19
i get problem when i try import obj in beldner.
so, i export obj from Moi3D in .obj format and default is 12 meshing options, when i want more poligons (high) i export.. problem is when i want import in blender i get this msg..
https://imgur.com/SbfVKY8
when i export from moi in 12 meshing opeions after that no problem.. everything is ok..
8754.21 In reply to 8754.20
Hi 4rw1n, looks like it could be a bug in MoI's mesh generation, strings like the -1.#IND000 are used for certain special floating point values that aren't regular numbers. They can result from the program reading from uninitialized memory or things like division by 0.
Can you please send the .3dm model file to me at moi@moi3d.com so I can test it over here and fix the bug?
If your model has extremely large or small coordinate values that might also be part of the problem.
8754.22 In reply to 8754.21
Hi Michael..
here is my .3dm model and also .obj what i cant open in blender..
https://files.fm/u/j3mfuq2j
here screenshot to see how i save and how export model.
https://imgur.com/zMK7mOY
8754.23 In reply to 8754.22
Hi 4rwin, the bug is in the automatically generated texture coordinates. If you're not using those you can turn them off by a setting in moi.ini :
[OBJ Export]
WriteTextureCoordinates=y
Set that to WriteTextureCoordinates=n and then that should avoid the error.
The error is just on 6 lines in the .obj file so it's also possible to edit the file and repair it.
I'll investigate it further to see if I can identify what particular surface triggers the bug and see if I can fix it.
Thanks, - Michael
Show messages:  1-3  4-23  24-33
