i need help
 1-2  3-22  23-33
8754.23 In reply to 8754.22
Hi 4rwin, the bug is in the automatically generated texture coordinates. If you're not using those you can turn them off by a setting in moi.ini :
[OBJ Export]
WriteTextureCoordinates=y
Set that to WriteTextureCoordinates=n and then that should avoid the error.
The error is just on 6 lines in the .obj file so it's also possible to edit the file and repair it.
I'll investigate it further to see if I can identify what particular surface triggers the bug and see if I can fix it.
Thanks, - Michael
8754.24 In reply to 8754.23
i cant find where i will turn off this texture coordinates
8754.25 In reply to 8754.24
Hi 4rw1n, in MoI go to Options > General and push the "Edit .ini file" button. On the dialog that pops up click the "Exit MoI and launch moi.ini" button.
MoI will close and the moi.ini file will open in notepad.
Inside notepad do a Ctrl+F to bring up the Find dialog. In "Find what:" type in texture and hit Enter. The window will scroll to WriteTextureCoordinates=y at the bottom. Edit that to be =n and then exit notepad and save changes.
If you then launch MoI and redo the export I think it should go into Blender ok then.
8754.26 In reply to 8754.24
Hi 4rw1n, there are 1 or 2 degenerate faces in the model with all their surface area completely trimmed away and the UV coordinate bug (division by zero) happens when processing those particular faces. I've got it fixed for the next v4 beta release. Thanks for reporting the problem and for sending the model so I could find the bug.
For the moment, turning off UV coordinate export as described above should avoid the bug.
8754.27 In reply to 8754.26
hi Michael, thank u a lot. now i can import .obj in blender..
really i never seen like this forum..everything what i ask i get answer..
8754.28 In reply to 8754.27
hello..
I keep working the tractor..i forget little moi3d long time im not use hhh.. but this program is very good and fast i back..
new picture..
https://imgur.com/5V6nJAS
https://imgur.com/vsXAyqf
i have some questions...its posible use color in moi and open in substance painter and use that color like color ID.. i think u understand what i ask..
8754.29 In reply to 8754.28
Does the import to substance painter involve UDIM uv's and/or fbx or OBJ import?
8754.30 In reply to 8754.28
Hi 4rw1n, MoI can export colors to .obj format, your list of styles in MoI will become the materials list and material assignments.
So try using that format for transferring over.
Message 8754.31 deleted 29 Oct 2018 by MICHAEL GIBSON
Message 8754.32 deleted 30 Oct 2018 by MICHAEL GIBSON
8754.33
Size: 322.2 KB, Downloaded: 54 times, Dimensions: 1748x1037px
Size: 367 KB, Downloaded: 45 times, Dimensions: 1748x1037px
Show messages:  1-2  3-22  23-33
