i need help
 1-13  14-33
8754.14 In reply to 8754.13
i have 2 picture, and from this 2 pictures i make hoot but not good.. i try find blueprints of MF 135, but dont have
so i really dont understand how to make hood, i make but this not perfect if u can help here is my project u only show how to make better..
project file https://files.fm/f/x77kpk6r
why this happen all is ok in cinema 4d and Moi#D but in Substance Painter get something wrong
see Cinema 4D and Moi#d is ok
https://imgur.com/a/eox2q
https://imgur.com/a/6lppp
and here is Substance painter , problem
https://imgur.com/bKfxLOK
8754.15 In reply to 8754.14
Hi 4rw1n, probably Substance painter doesn't like to deal with complex n-gons. When you do the export out from MoI try using the "Output: Quads & Triangles" option instead of "Output: n-gons" and see if that works better.
8754.16 In reply to 8754.15
thank u michael, its working!
8754.17
heloo.. that i dont open new topic i will write here..
i have problem, my english not good but i will try explain..
when i make some object and use tranform mirror after that i get 2 object same its ok.. but when i mark only 1 that object and rotate also another object rotate, i want only one rotate..
8754.18 In reply to 8754.17
Hi 4rw1n,
Sounds like past History is associating the mirror copy with the original.
I think the History command can break the "connection."
http://moi3d.com/forum/index.php?webtag=MOI&msg=8475.2
http://moi3d.com/forum/index.php?webtag=MOI&msg=7940.1
EDITED: 13 Jan 2018 by BEMFARMER
8754.19 In reply to 8754.18
its work.. thank u!
8754.20 In reply to 8754.19
i get problem when i try import obj in beldner.
so, i export obj from Moi3D in .obj format and default is 12 meshing options, when i want more poligons (high) i export.. problem is when i want import in blender i get this msg..
https://imgur.com/SbfVKY8
when i export from moi in 12 meshing opeions after that no problem.. everything is ok..
8754.21 In reply to 8754.20
Hi 4rw1n, looks like it could be a bug in MoI's mesh generation, strings like the -1.#IND000 are used for certain special floating point values that aren't regular numbers. They can result from the program reading from uninitialized memory or things like division by 0.
Can you please send the .3dm model file to me at moi@moi3d.com so I can test it over here and fix the bug?
If your model has extremely large or small coordinate values that might also be part of the problem.
8754.22 In reply to 8754.21
Hi Michael..
here is my .3dm model and also .obj what i cant open in blender..
https://files.fm/u/j3mfuq2j
here screenshot to see how i save and how export model.
https://imgur.com/zMK7mOY
8754.23 In reply to 8754.22
Hi 4rwin, the bug is in the automatically generated texture coordinates. If you're not using those you can turn them off by a setting in moi.ini :
[OBJ Export]
WriteTextureCoordinates=y
Set that to WriteTextureCoordinates=n and then that should avoid the error.
The error is just on 6 lines in the .obj file so it's also possible to edit the file and repair it.
I'll investigate it further to see if I can identify what particular surface triggers the bug and see if I can fix it.
Thanks, - Michael
8754.24 In reply to 8754.23
i cant find where i will turn off this texture coordinates
8754.25 In reply to 8754.24
Hi 4rw1n, in MoI go to Options > General and push the "Edit .ini file" button. On the dialog that pops up click the "Exit MoI and launch moi.ini" button.
MoI will close and the moi.ini file will open in notepad.
Inside notepad do a Ctrl+F to bring up the Find dialog. In "Find what:" type in texture and hit Enter. The window will scroll to WriteTextureCoordinates=y at the bottom. Edit that to be =n and then exit notepad and save changes.
If you then launch MoI and redo the export I think it should go into Blender ok then.
8754.26 In reply to 8754.24
Hi 4rw1n, there are 1 or 2 degenerate faces in the model with all their surface area completely trimmed away and the UV coordinate bug (division by zero) happens when processing those particular faces. I've got it fixed for the next v4 beta release. Thanks for reporting the problem and for sending the model so I could find the bug.
For the moment, turning off UV coordinate export as described above should avoid the bug.
8754.27 In reply to 8754.26
hi Michael, thank u a lot. now i can import .obj in blender..
really i never seen like this forum..everything what i ask i get answer..
8754.28 In reply to 8754.27
hello..
I keep working the tractor..i forget little moi3d long time im not use hhh.. but this program is very good and fast i back..
new picture..
https://imgur.com/5V6nJAS
https://imgur.com/vsXAyqf
i have some questions...its posible use color in moi and open in substance painter and use that color like color ID.. i think u understand what i ask..
8754.29 In reply to 8754.28
Does the import to substance painter involve UDIM uv's and/or fbx or OBJ import?
8754.30 In reply to 8754.28
Hi 4rw1n, MoI can export colors to .obj format, your list of styles in MoI will become the materials list and material assignments.
So try using that format for transferring over.
Message 8754.31 deleted 29 Oct 2018 by MICHAEL GIBSON
Message 8754.32 deleted 30 Oct 2018 by MICHAEL GIBSON
8754.33
Size: 322.2 KB, Downloaded: 54 times, Dimensions: 1748x1037px
Size: 367 KB, Downloaded: 45 times, Dimensions: 1748x1037px
Show messages:  1-13  14-33
