rounding off corners...?
8738.1
Hi all, I've been watching a tut on Youtube called "Moi3D hard surface" and have been following along but have run into a wall. What am I doing wrong? I'm trying round off the corners. He used the fillet tool which doesn't work for me yet I would have the the chamfer tool would be better to use. In any case that didn't work either. If I'm missing something please let me know.
8738.2 In reply to 8738.1
Hello,
I think the grid is set at 1mm right, so your smallest edge in the drawing is 1 mm. Try a fillet value smaller than 0.5 mm (0.4 mm should work).
8738.3 In reply to 8738.1
Hello,
it seems that the fillet is to big. Try to make the fillets one for one. Check if the radius of the fillet is not bigger than the shortest line.
Good luck
Karsten
8738.4 In reply to 8738.3
Thanks for the reply, It seems to be working now after closing and opening Moi again. I used .5 fillet on this. Strange. I appreciate your feedback, thx!
Size: 531.2 KB, Downloaded: 62 times, Dimensions: 1680x1050px
