Extend line ?
All
1-4
5-7
SebKaine
5 Oct 16:11 (5 of 7)
8735.5
In reply to
8735.4
Hi , is it still the case ?
i am searching for the equivalent of the maya extend curve feature.
https://help.autodesk.com/view/MAYAUL/2027/ENU/?guid=GUID-08E73E34-DEAE-4E5B-98DA-CFB4560C06E8
basically
- you select a curves.
- you enter wich part you want to extend ( start, end or both )
- you enter the distance of the extend
- you enter the continuity method
is there an alternative in Moi 3D ?
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
777RAVEN777
5 Oct 18:22 (6 of 7)
8735.6
In reply to
8735.5
Perhaps simply selecting points and then using Scale 1d?
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Frenchy Pilou (PILOU)
5 Oct 19:48 (7 of 7)
8735.7
Draw a Circle by center from the last point of a curve with the radius of length wished!
Select the curve
Call function Menu Edit / Extend
Click Circle
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Reply to All
All
1-4
5-7
