Extend line ?
All  1-2  3-7
8735.3 In reply to 8735.1
Hi Bruno, currently the regular Extend command in MoI can only extend to a boundary. I do want to add more functionality to Extend in the future but for now I'd recommend just drawing a line at the end of your curve and joining it to the original curve.
8735.4 In reply to 8735.3
Great! Thanks Michael. I am enjoying Moi quite a lot.
8735.5 In reply to 8735.4
Hi , is it still the case ?
i am searching for the equivalent of the maya extend curve feature.
https://help.autodesk.com/view/MAYAUL/2027/ENU/?guid=GUID-08E73E34-DEAE-4E5B-98DA-CFB4560C06E8
basically
- you select a curves.
- you enter wich part you want to extend ( start, end or both )
- you enter the distance of the extend
- you enter the continuity method
is there an alternative in Moi 3D ?
8735.6 In reply to 8735.5
Perhaps simply selecting points and then using Scale 1d?
Draw a Circle by center from the last point of a curve with the radius of length wished!
Select the curve
Call function Menu Edit / Extend
Click Circle
Show messages: All  1-2  3-7
