Considering buying MOI to do this
 1-9  10-29  30-49  50-69
8732.50 In reply to 8732.46
< distorted.
Just that following materials and sizes used any curves can't be realized! ;)
So more fluent more easy...
Your cube is for a jewel ?
EDITED: 20 Dec 2017 by PILOU
8732.51 In reply to 8732.50
LOL :)
Technic of Gaudi can't be applied here ?
8732.53 In reply to 8732.47
I will go for your technique without looking the discontinuity. If MOI and Modo can translate good I might correct the ''problem'' through erasing some polygons or edges.
I will also try the technique of Karsten with the G3 cube. I am curious to see how will be the result.
Thanks so much for your time again.
8732.54 In reply to 8732.49
Karsten thanks so much. Today I am going to try with the G3 cube. I remember you said you used two rails and one profile in an oldest post.
Now you did a new technique I think. With 8 profile and 2 rials and rebuilding.
I will come back with results of your first attempt ( since that rebuilding and making 8 profiles for each groove...will be an experiment that will need more time).
Thanks so much!
8732.55 In reply to 8732.50
Furniture ;)
8732.56 In reply to 8732.52
Mmm I think Gaudi used that technique in order to calculate the structure tension-forces of Sagrada Familia.
I love that place. Thanks! I will apply it to my cube
8732.57 In reply to 8732.49
Hi Karsten,
How did you do the curvature anylsis it looks like it’s in Moi.
Is there a script for it ?
Barry
8732.58 In reply to 8732.57
Hello Barry,
there is a script called CCC (calculate curves curvature) and a curvature node with the psychodellic colors. The disadvantage is the node throws 255 new styles to the file. For each color of the rainbow one ;-) You will find it under Infos in the extensions. You can switch also to a radius mode, only useful when the curve has no straight segments. With scale factor 1 the lines shows you the center of the local radius. Min and Max radius is also evaluated. Useful for e.g. sweeps with a circle as profile. then you can compare local radius of the curve with the profile radius and know if the resulting surface will be squeezed.
Have a lot of fun with it, it was a lot of work;-)
Karsten
8732.59 In reply to 8732.58
Hi Karsten,
thanks for the info will take a look.
Barry
8732.60 In reply to 8732.59
Curvature analysis is an objective judgment of the quality, sometimes it's hard to see the bullshit I have produced. But then there is no space left for a discussion about the result. And then - again!
8732.61 In reply to 8732.60
Hi Karsten,
found the node, tried it and found a practical use for it.
The max and minimum radii function is useful when machining a profile and the minimum cutter diameter needs to be known.
So keep up the good work with creating nodes I enjoy the challenge of using them for solving practical problems.
Barry
<< there is a script called CCC (calculate curves curvature) and a curvature node with the psychodellic colors.curves curvature) and a curvature node with the psychodellic colors.
Sorry where is it ?
8732.63 In reply to 8732.62
Hello Pilou,
http://moi3d.com/forum/index.php?webtag=MOI&msg=6634.14 The script without coloring and the node is in the extensions under infos. Insert the node, connect a curve to it and the out to an output. Press run - that's it.
Have a nice evening
Karsten
8732.64 In reply to 8732.63
@ Karsten
Ok I answer on the other thread about curvature info!
8732.65
Few things. I will put today and Friday as my deadline to finish this model.
I started with Michael's technique. To reconstruct some segments and then have the same amount in both profiles in order to have an even 'surface'.
I started with one of the corners. My idea is to get rid of the discontinuity in Modo. I am planning to uv the model so I guess I can spend some time to eliminate the polys that generate the wrinkle.
I did find a problem joining the grooves. It seems the cap and the first groove are joined (the surfaces get highlighted when I touch them). The other grooves give me the 'two surfaces joined' sign , but when I click on them they do not look together. Also when I apply a fillet edge on the edges (I would like to have a tiny radius in each sharp edge) nothing happens.
You can find the file attached too.
I also wanted to know if its possible to visualize the 'isocurves' of the model in MOI, so I can avoid jumping in to Rh.
Also I wanted to know if there is any tutorial regarding how to export efficiently to MODO or other polygonal software.
So far this is the best I could get playing around:
In the meantime I will check the manual.
8732.66 In reply to 8732.65
Hello Bruno,
your surfaces are not well connected - to check it use this script as a shortcut:
script:var gd = moi.geometryDatabase; gd.deselectAll(); var breps = gd.getObjects().getBreps(); for ( var i = 0; i < breps.length; ++i ) breps.item(i).getNakedEdges().setProperty( 'selected', true );
Open the options and go to the short cut keys and press add. copy the script under command in the free field. Choose a shortcut in the first free field and close. Now press the shortcut and look what happens - the script will mark open edges. Showing isolines is only possible for a single surface/face. You can use Curves - isocurves for that.
Is the idea for this cube made by Ernő Rubik?
Have a nice day
Karsten
8732.67 In reply to 8732.66
Hi Karsten.
This project? mMM Rubik cube ? mmm nope. Its furniture that I want to cnc.
I will try with your script. The strange thing is ...I am not understanding how am I getting naked edges...when I am using the rials and profiles of intersections...
I am not imagining how a sweep can leave gaps...if i am sharing the rials (???)
Anyway when you say they are not well connected...is this affecting the fillet or exporting...or both.
8732.68 In reply to 8732.65
Hi Bruno,
Sorry no there isn't any way for an isocurve display in MoI. Is there a reason why you're concerned about the isocurve structure in particular? It tends to be better to focus on whether a surface has a good shape or not. The density of the isocurve display in Rhino has to do with a low level NURBS detail of how many "knots" the surface has. It's not particularly something that is necessary to worry about compared to issues like shaping and accuracy.
Typically all an isocurve display tends to do is get in the way of seeing the surface shape more clearly, that's why it's not implemented in MoI.
Usually it's best to crank the slider more towards the right rather than towards the left as you're showing there, and then sometimes it can also help to use "Divide larger than" as you have done there. Also usually I'd recommend having "Weld vertices along edges" to be turned on.
Also for Modo .lwo is usually the preferred export format, for other polygonal software it's usually .obj format.
8732.69 In reply to 8732.67
Hello Bruno,
attached is a file with the generating curves, I have used. The magenta curves was used to place the profiles. After placing them, I made a copy and joined them together again. The joined curves I rebuild -> select them all - press the tab key and type rebuild - standard tolerance 0,01. After that I've used two of them as rails for each sweep. If you can't join the results together, there is a trick. Select them all and scale them down by a scale factor of 0,01. After that press join without to deselect. After that scale them up with scale factor 100. So you get back your surfaces joint. The scale down lowers the gap between the surfaces under the threshold of what MoI accept as coincident means 0,005 units!? The connection information will not be lost while scaling up back. Have a look if the method used here works for you, if not I can't help.
Have a nice day
Karsten
EDITED: 28 May 2018 by KMRQUS
Show messages:  1-9  10-29  30-49  50-69
