Considering buying MOI to do this
 1-4  5-24  25-44  45-64  65-69
8732.5 In reply to 8732.3
Hi Bruno, sure no problem you can e-mail it to me at moi@moi3d.com , I'm just about ready to go to sleep over here so it will be a little while before I'm able to reply.
8732.6 In reply to 8732.5
Ups- sorry Bruno. I was to fast, but it differs from yours!
Sleep well Michael!
8732.7
Hi Bruno,
is this the type of result you want. I just sliced a cube in Moi only 2 minutes.
Hope this helps.
Barry
8732.8 In reply to 8732.4
Wow...looks awesome. Even if it has a lot of iso-curves...they all align . I need to test in Modo as an obj!
Is it possible to blend curves in Moi ? ? I can also import my curves from Rhino. Do you think they will behave equally ...rhino compared to making it again entirely in MOI?
Again...the idea is to have clean polygon mesh in Modo.
8732.9 In reply to 8732.7
I need to start from there. Then I need to build the two profile to curve to sweep along the rials. I used the blend crv in Rhino.
It seems I could do this entirely in MOI with half of the hassle.
Thanks so much for your help!
8732.10
Do you think I can avoid the process to send it to MODO to UV map it ? It looks so cool in MOI already.
When I export the model you generally uploaded..polygon start to get a little bit weird. Still much much better than Rh outcome so far.
I will start to re build it in Moi!
8732.11 In reply to 8732.10
Hi Bruno,
this is produced by projecting lines onto the cube. These can be used as rails to sweep a profile.
Barry
8732.12 In reply to 8732.11
...Moi is so far the very best tool for a 3D designer!
For concept creations and ultrafast products presentation there's nothing into the actual 3D consumer modeler market that can compete against Moi.
Less than 10 minutes and you can create stunning and strange pieces of industrial design concepts :)
Marco (mkdm)
8732.13 In reply to 8732.12
It seems so!
8732.14 In reply to 8732.11
I will get back with a screen shot of the exact cube I need in MOI. Then I will find the way how to project the lines I need.
Thanks so much...this is the concept. Now I need to find the way to do exactly what I need in dimensions. Its my first day with MOI so I probably will back to you.
8732.15
Ok I am starting. I have a few questions. Not sure if I should open a new topic.
I am building the rials.
1. Did the polysurface + Radius
2. build a grid with an array to place my diagonals
3. Manually draw each line between vertex (please see the attachment)
4. Mirror them in order to build a loft = surface
5. Intersected them.
Questions: Is there any way to project the lines faster? Maybe a contour ? Maybe an offset of each oblique line ?
I seen some of the users built it super fast. I would like to ask you the procedure to make the projections that you use .
Thanks a lot
Bruno
Size: 535.6 KB, Downloaded: 31 times, Dimensions: 1546x1569px
8732.16 In reply to 8732.15
Hi Bruno,
try this.
Barry
8732.17 In reply to 8732.16
Thanks @Barry-H .
Getting there. Tomorrow I will continue.
Size: 578.3 KB, Downloaded: 41 times, Dimensions: 1926x1610px
8732.18 In reply to 8732.8
Hi Bruno,
Yup, select your curves and then run the Construct > Blend command.
One of the differences between MoI and Rhino is that MoI doesn't have separate commands for doing things to curves and surfaces, there's just one Blend command and it will do either a curve blend or a surface blend depending on what you have selected.
8732.19 In reply to 8732.15
Hi Bruno,
I'd probably make one line and then use Transform > Array > Dir to duplicate it to make the rest of them.
8732.20 In reply to 8732.18
Thanks Michael. I also noticed that the blend has less options than Rhino. For example the ends of the blend are managed always under the same continuity.
Is this right ?
8732.21 In reply to 8732.19
That was the technique! Thanks!
8732.22
I tried making one surface with Rhino imported curves and other one natively in MOI.
I must say the result is the same. Please not misunderstand. The sweep was always performed by MOI which looks neater.
I am just thinking that I could import all my lines from Rhino. I just wanted to check if this is as expected to happen. As long as the procedure is performed by Moi the structure in Rhino will not change the behavior in respect to the one made in Moi.
Thanks a lot.
You can check here.
Red one is coming from Rhino. Grey Moi. In order to see the isocurves I imported to Rhino again both.
8732.23 In reply to 8732.20
Hi Bruno,
> Is this right ?
Yes, that's correct. If you need a really fancy blend with different continuity for each individual end I'd recommend doing it in Rhino and then bring it back into MoI. You can use copy/paste Ctrl+C/Ctrl+V to move objects back and forth between MoI and Rhino quickly.
8732.24 In reply to 8732.22
Hi Bruno,
Sorry I'm not quite following this part, what is the question exactly?
> Thanks a lot.
> You can check here.
Did you mean to attach something to your post? I didn't see anything. Also it really does help if you can post a 3DM model file that can be loaded and zoomed and rotated around and inspected in detail rather than only an image, you can e-mail them to me at moi@moi3d.com if you want, if you sent one previously please re-send it as I don't seem to have received any.
Show messages:  1-4  5-24  25-44  45-64  65-69
