V4 beta Dec-12-2017 available now
 1-4  5-24  25-44  45-64  …  165-176
8731.5 In reply to 8731.4
Yes the MagicMouse behaves well now :-)
Thanks a lot!
But the new ShortKey function..
this works: Line bothsides=true
this is not working: Box3pts WidthHeight width=2 height=4
Win and Mac
Ralf:)
looking for moments of inspiration...
French Site Updated
http://moiscript.weebly.com
@Michael (just a little very cosmetic error from my part) (3 times in French "objects" must be "objets" tiny isn't it! : escaped till now! :)
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/frenchstrings.zip
EDITED: 12 Dec 2017 by PILOU
8731.7
Thank you Michael for your persistent bug eliminating. Mac full screen mode works fine in OS X 10.9.
-Martin
8731.8 In reply to 8731.7
Hi Michael
I've found a bug.
Step by step :
open MoI v4 beta Dec-11-2017
open Option panel
close it
> crash
I sent you the crash report
<<open MoI v4 beta Dec-11-2017
<<open Option panel
<<close it
<<> crash
Not for me :) Windows 10
8731.10 In reply to 8731.8
Same here on Mac....
But also (sometimes) while changing ShortKeys..
Ralf:)
8731.11
Hey Michael, I am having some problems with shortcut keys on the Mac. Fist there are duplicate entries for things like undo (Cmd+Z on the Mac) it also has a Windows entry of Alt+Z. I can't seem to set any shortcuts using Cmd+. I sometimes get a crash when attempting to set shortcuts. Crash report attached.
-Shane
rendering . animation . oddlyeven.com
8731.12 In reply to 8731.5
Hi Ralf,
It looks like here you are trying to use the new variation of the box 3pt command that I posted yesterday?
The problem here is that the command name for that is Box3ptsWidthHeight, without any spaces in it, you've got a space in the middle of yours above.
8731.13 In reply to 8731.6
Thanks, I've updated this for the next beta.
8731.14 In reply to 8731.11
Hi Shane,
Yes, there's still a problem with Alt+ and Cmd+ getting confused with each other. I'll be looking at that for the next beta and I'll be checking out the crash today, thanks.
8731.15 In reply to 8731.1
re: options dialog crashing on close on Mac, looks like one of the changes for fixing the "mouse moves get ignored in some conditions" are causing that. I'll roll out an updated version soon.
Seems a Mac a very sensible machine ? ;)
8731.17 In reply to 8731.16
Hi Pilou, well this latest crash is from a mistake I made, it happens to be in an area of mouse event handling that is by its nature kind of sensitive.
There are some things that I have found frustrating with the Mac though, like the full screen mode and the "spaces" mechanism is very poorly documented and hard to control.
But I expect things to be reaching a good level of stability soon here.
8731.18 In reply to 8731.8
Hi Finema & Ralf & shane - re crash on closing options dialog on Mac, I just updated this to a new Dec-12 version which should hopefully fix that, please let me know if you still see it.
Thanks, - Michael
8731.19 In reply to 8731.18
Thanks for the update, it's OK now.
8731.20 In reply to 8731.19
That's great Finema, thanks for testing it! There are still some things to fix but hopefully we should be at a pretty stable version now.
Does it necessary to reload the PC version ?
8731.22 In reply to 8731.12
<<<<<The problem here is that the command name for that is Box3ptsWidthHeight, without any spaces in it, you've got a space in the middle of yours above
Yes but i tried different versions with or without space...
Looks like its not implemented right now..
Ralf:)
8731.23
Hello Michael,
for me on Win10, F10 Shortcut is not working, in previous beta this was OK.
- Scarab
Size: 1.1 MB, Downloaded: 97 times, Dimensions: 2304x1296px
8731.24 In reply to 8731.21
No there's no changes for the Windows version.
Show messages:  1-4  5-24  25-44  45-64  65-84  …  165-176
