V4 beta Dec-12-2017 available now
 1-20  …  101-120  121-140  141-160  161-176
Message 8731.141 deleted 24 Jan 2018 by BEMFARMER
8731.142
Hi, Michael Gibson, I am a user of trial version now, but I want to purcase the program. Seems like you improve the V4 a great deal, and I really like version 3, but there is a minor (in terms of implementation) thing, that can have a very huge impact, since I know people who tried MoI and basically because of a single thing decided to use other program. This thing is interface. In particular, line weight on the model and on the grid. See, because of thick lines the whole model or scene can look dirty. And, increasing the complexity it will look dirtier and dirtier. It's about anti-aliasing as I understand. Will you implement thin and elegant lines insetead of thick lines? Thank you.
And, maybe, make options to change the UI colour (light-blue and orange), built in MoI, not through external ways. Maybe, change the icons to more minimalistic and clean, maybe with more sharp edges. You will see, more people will be willing to use clean and pretty looking program.
Besides UI, there is a fillet thing that MoI can't do, it seems. Is it possible to improve filleting?
Thank you.
Size: 30.7 KB, Downloaded: 110 times, Dimensions: 620x240px
Size: 31.1 KB, Downloaded: 114 times, Dimensions: 580x243px
8731.143 In reply to 8731.142
Hi Alex, there is an option you can set to use thinner antialiasing, see here for more information:
http://moi3d.com/forum/index.php?webtag=MOI&msg=5961.2
I'm sorry but I don't really view the look of the icons to be very significant, it's just not something that is a priority right now. It is possible to customize them yourself if you want by editing the PNG files in the \ui sub-folder.
Filleting is something that I would like to improve in the future but I'm not sure when it will happen, there is a lot of work involved. If difficult filleting is a priority for you, some other CAD program would probably work better than MoI for that type of use.
8731.144 In reply to 8731.143
Thank you, Michael, it looks very nice now.
Understandable about icons.
Sometimes fillets can be difficult, but no program can be so fast as MoI, it seems, with all the hotkeys, snapping and no splitting between solid and sketch modules. I like MoI.
Have a good day.
8731.145 In reply to 8731.144
Hi Alex, I'm glad that helped!
Some people like to use MoI in combination with other CAD programs for handling filleting that MoI isn't able to do on its own yet.
Some good candidates for that type of use are ViaCAD, OnShape, and Fusion 360.
8731.146 In reply to 8731.145
Hello Michael!
How are you ? I hope fine :)
Did you plan to release a new beta soon ?
8731.147 In reply to 8731.146
Hi Marco, doing fine here, thanks! Yes probably not too much longer for the next beta. Maybe Sunday, we'll see.
8731.148 In reply to 8731.147
Thanks!!
8731.149 In reply to 8731.148
Hi Marco - a couple more days yet for the next beta.
8731.150 In reply to 8731.149
Wanderful!!
Thanks a lot!
8731.151 In reply to 8731.149
Great news ...
Thanks Michael.
eric
8731.152
Phantastic.
Can we hear what will be the innovations in the next beta.
8731.153 In reply to 8731.152
Hi Rudl, well there are a lot of various bug fixes, it will take me a while to collect up all the information so I'll do that after it's ready.
But hopefully it will be a turning point where I'll be able to focus mostly on brand new features after this release.
Hello Michael!
When you can start to work on "new things", please add this little but very very useful feature :
The chance to capture Moi's viewport, like already Moi does, but with the addition of a flag or a scripting variable, to get a transparent background.
This feature would be perfect for everyone like me is often engaged in creation of 2D/3D image composition in print quality resolution.
Thanks a lot!
8731.155 In reply to 8731.154
Hi Marco,
I actually looked into that when you mentioned a month or so ago, but unfortunately I found that it is not a simple matter to incorporate that into MoI's current viewport display engine. Curve drawing is the part that makes it difficult - the display engine is expecting to blend the curves against a colored background and it's problematic for curves to write alpha values.
It's more straightforward with something that draws shaded polygons and not curves, and you can get that type of image out of MoI currently by exporting to .ai format, if you turn on the Shaded background image option a companion PNG file will be generated along with the .ai file.
8731.156 In reply to 8731.155
@You : "...It's more straightforward with something that draws shaded polygons and not curves, and you can get that type of image out of MoI currently by exporting to .ai format, if you turn on the Shaded background image option a companion PNG file will be generated along with the .ai file."
Ok Michael. I forgot this chance :)
I will try and let you know if it's good for what I want to do (image composition in very high resolution).
8731.157 In reply to 8731.155
Hi Michael!
I've tested and exported in AI in order to get hires images and the procedure is almost OK! :) Thanks for reminder.
But...I have only a final problem. What can we do to solve it ?
The problem is I need very very high resolution images (up to 16Kx16K) because actually Moi doesn't apply any kind of antialiasing to the generated images,
and I have to use the "trick" to have a very big image that I can scale down to about 4K or 2K in order to "blur" its edges and make, in this way, a sort of "manual antialiasing".
The problem is that in Moi, even if I specify a canvas resolution of 110 megapixel, the generated image file can reach a max resolution of 11039 x 6795, that is absolutely not 110 megapixel :)
You can see this behavior in these images :
I stay tuned. Thanks!
Marco (mkdm)
And using this plugin ? You can put any resolution (following your hard memory avaible)
script: /* Print screen to the Clipboard */ var prev_background = moi.view.viewportBackgroundColor; moi.view.viewportBackgroundColor = 0x000000; moi.view.lineWidth = 4; moi.grid.display = false; moi.grid.showXYAxes = false; moi.ui.getActiveViewport().renderToClipboard( 2560, 2560 ); moi.view.lineWidth = 1; moi.grid.display = true; moi.grid.showXYAxes = true; moi.view.viewportBackgroundColor = prev_background;
8731.159 In reply to 8731.158
Ok.
But...I'm sorry Pilou...I already know these things and they works very well but I was talking about the chance of having
the "viewport" captures not only in super hires but also with transparent background, and that feature is available only
in export to AI, but it seem that that command can't generate images grater than 110396 x 6795 and I need more.
Ciao!
8731.160 In reply to 8731.157
Hi Marco,
re: 11039 x 6795 not adding up to 110 megapixels - I'll take a look at the calculation it's probably related to the aspect ratio of the image.
But if you need such a high resolution you'll probably need to use a rendering program to get it rather than using this feature in MoI.
Show messages:  1-20  …  81-100  101-120  121-140  141-160  161-176
