DXF related question
All  1-15  16-18
8703.16 In reply to 8703.15
Well... a bit of progress to report:
Discovered a setting in the Blender DXF import dialog-box that allows for the avoidance of item merging.
Of course it does not provide the same sequence value as the original, but at least I can use it❗
Please, let me know if there is a better fix.
I couldn't find information on the other merge options, so I left them at their default.
Moi Bueno
MindSet
8703.17 In reply to 8703.15
Hi MindSet, object names do not get written to DXF format because as far as I know there isn't a concept of an object name there.
The main thing that has name labels in DXF is layers, and the style names in MOI should be preserved in the layers list in the generated DXF file.
If you have any DXF files that do import into Blender with object names coming through please send them to me so I can see how they are set up.
8703.18 In reply to 8703.17
Thank you Michael,
Of course you are correct.
Once I found that check box in Blender, I was off and running.
I appreciate you entirely!
Moi Bueno
MindSet
Show messages: All  1-15  16-18
