V4 beta Nov-18-2017 available now
 1-11  12-31  32-51  52-71  72-91  …  132-137
What is the structure Folders / Files of the Max Smirnov Node Editor with the V4 inside the Moi Folders / Files itself?
8682.33 In reply to 8682.32
Hi Pilou, there is installation information for the node editor on the wiki here:
http://moi3d.com/wiki/Nodeeditor
You're supposed to copy the node editor folder inside of MoI's ui folder.
8682.34 In reply to 8682.33
Thx for the precision!
French Gear for V4 by Max Smirnov! (Windows 10)
http://moiscript.weebly.com/engrenages.html
EDITED: 21 Nov 2017 by PILOU
Glitch for Nuts & Bolts by Max Smirnov (V4) (Windows 10)
French SSPlit by Max Smirnov V4 (Windows 10)
http://moiscript.weebly.com/bridge.html
French version of the SBridge by Max Smirnov (V4) (Windows 10)
(easy: nothing to translate for this one! :)
8682.38 In reply to 8682.29
Many thanks for the updated versions of your scripts and commands, Max, your support to the MoI community is invaluable.
Regards,
Metin
visualization • illustration • animation • 3D (print) design — https://metinseven.com
8682.39 In reply to 8682.38
Hello.
...I've often wondered what would happen if Michael and Max were working together some day...
That could be great I think :)
Ciao!
Sorry need more infos about the Max Editor for the V4!
there is now editor.css & editor.js (edited in November)
so what is now the new structure and what put in this new structure?
UI/nodeeditor/ editor.css ...
or
UI/editor/ editor.css...
need more folders/files ?
or ...
What about nodeditor.zip of october?
I am in the fog! :)
8682.41
@ Marco: Max and Michael make a fine team indeed.
A little note regarding V4: I'm very happy that because of the native MacOS support I can finally use Default Folder X for fast access to favorite and recent folders. I really missed that in the WINE V3.
In case you're a Mac user too and don't know Default Folder X yet, I can heartily recommend it:
http://www.stclairsoft.com/DefaultFolderX/
It's created by a hard-working independent developer who provides excellent user support, like Michael.
Regards,
— Metin
8682.42
A little request:
Right now the MacOS MoI V4 beta doesn't allow keyboard shortcut columns to be resized in the Preferences. This results in unreadable entries like this:
In this case it's not visible which Numpad keys are assigned to the Boolean functions. As I use the keyboard shortcut list often as a reminder which keyboard shortcuts I've assigned to functions, I'd like to be able to resize the columns if that's not a hassle.
In case it's not difficult, I'd also welcome an alphabetical sort option when clicking on a column header.
I'll also post this in the V4 wishlist discussion.
Thanks in advance.
Regards,
— Metin
8682.43
I don't know if this has already been mentioned, but I noticed a bit of lag when dragging a selection range to select curve points in Show Points mode. The lag isn't there in the WINE V3.
— Edit: I also just noticed the lag when panning the viewport, with several curves and selected points visible.
I also noticed that when you drag across the radius input value field of a selected curve, if you touch the "Radius" text, it will change to Diameter while you're still dragging to select the value.
My system specs:
• iMac (27-inch, Late 2013)
• MacOS High Sierra, version 10.13.1
• Processor: 3.5 GHz Intel Core i7
• Memory: 16 GB 1600 MHz DDR3
• Graphics: NVIDIA GeForce GTX 780M 4 GB
• Wacom Intuos Pro tablet + pen, latest drivers
EDITED: 21 Nov 2017 by METINSEVEN
8682.44 In reply to 8682.39
If MICHAEL builds a nice interface in MoI v4 for plugins (installing, search for new, update...)
MAX could sell his unbelievible and usefull Scripts for a fee...
And WE have the fun :-)
8682.45 In reply to 8682.40
Hi Pilou.
For Windows7,
ProgramFiles/MoI4.0betaNov-18-2007/ui/nodeeditor/core/css/editor.css
MoI4...2007/ui/nodeeditor/core/editor.js
("same" as for MoI3 IMHO)
8682.46 In reply to 8682.45
@Bem : Thx ! That was not clear for me! :)
some files from November must to be remplaced the october ones! (2)
nodeeditor.css in C:\Program Files\MoI 4.0 beta Nov-18-2017\ui\nodeeditor\core\css\nodeeditor.css
nodeeditor.js in C:\Program Files\MoI 4.0 beta Nov-18-2017\ui\nodeeditor\core\nodeeditor.js
Now all is clear! :)
At first glance nothing to translate for general use! :)
For old nodes of course!
Does all the nodes of the // Elephant (Mkdm, Karsten, Al2000..) will work on this new version or they must be adapted too ?
8682.48 In reply to 8682.47
CycloidGear11_to_1, and motor2017 run very well.
8682.49 In reply to 8682.29
Hello Max.
This is a detailed report of the testing I've made so far on some of your scripts :
(please check the "FAIL TESTING" section)
SUCCESSFUL TESTING :
SCRIPTS UPDATED ON NOVEMBER 2017 :
OK : NutsAndBolts.v.0.96.2015.06.22.zip (Sun Nov 19 00:15:05 2017)
OK : FatLines.v.0.6.2017.11.17.zip (Fri Nov 17 00:13:10 2017)
OK : sSplit.v.0.95.2015.08.10.zip (Thu Nov 16 23:44:37 2017)
OK : sBridge.v.0.71.2015.03.26.zip (Thu Nov 16 23:25:04 2017)
OK : Gear.v.1.0.2014.09.26.zip (Thu Nov 16 22:51:13 2017)
SUBDIV SCRIPTS :
Ok : SubdivBeta.v.6.1.2015.03.05.zip (Sat Aug 29 15:55:16 2015)
OTHER OLDER SCRIPTS :
OK : RandomCurves.v.1.0.2014.01.25.zip (Tue Nov 4 21:25:12 2014)
OK : PatternSelection.v.0.3.2014.02.20.zip (Tue Nov 4 21:16:34 2014)
OK : DistortCurves.v.1.0.2014.11.04.zip (Tue Nov 4 01:23:30 2014)
FAIL TESTING :
ERROR : Cloth.v.0.96.2014.02.23.zip (Mon Nov 3 23:56:24 2014)
Watch this brief video : http://take.ms/peCkR
ERROR : cMorph.v.1.1.2014.01.19.zip (Mon Nov 3 23:46:56 2014)
Watch this brief video : http://take.ms/RT7K2
We'll catch up.
Ciao!
8682.50 In reply to 8682.1
Hello Michael.
During my random testing session of V4 I noticed that this shorctut key isn't fired up :
Ctrl+Shift+1 (I use it for show-hide edges on selected objects)
Also, if I try to edit this shortcut key and try to reassign it to the "Ctrl+Shift+1" combination,
when I hit the Ctrl+Shift and then the "1" key, I get "Ctrl+Shift+!" because I have an Italian keyboard :
Please check this brief video : http://take.ms/0xhsc
With the V3 I have the same keyboard shortcuts but all works fine.
Please, let me know what I have to do.
P.S. As mentioned also by another user (I don't remember who), please give us the chance to resize the first column of the shortcut key editor.
I stay tuned.
Ciao!
_nutsandbolts not works for me! (Windows 10)
Show messages:  1-11  12-31  32-51  52-71  72-91  92-111  …  132-137
