V4 beta Nov-18-2017 available now
 1-3  4-23  24-43  44-63  64-83  …  124-137
8682.24 In reply to 8682.17
Hi Michel and Martin - for the full screen mode sliding away that hint Michel gave about it only happening when moving over a viewport was very helpful. It turns out that it's caused by the little view controls panel window that's shown at the bottom of viewports. That little window is getting shown back on the original desktop space and when that happens the OS zooms you back there again. Now that I know what's happening I can work on a fix, thanks!
If you turn off the view controls panel under Options > View > "Show view controls" you should see that you won't get sent back to the desktop in full screen mode anymore.
French Version of Flat lines by Max Smirnov updated for the V4! :)
http://moiscript.weebly.com/scripts-de-max-smirnov.html
EDITED: 20 Nov 2017 by PILOU
8682.26 In reply to 8682.24
Confirmed.
I had first thought that it was a OSX Spaces problem like the Sub windows (drawing frames) not being considered to belong to the Main window thus generating an out of focus.
I'd never suspected the control panel of these windows.
That also explains the seemingly random triggering happening afterwards.
When reactivated, the 3d pane won't trigger the sliding because the control panel was redrawn in the 3d pane.
But, when entering into one of the other drawing areas, the control panel appears in the original desktop space and triggers the sliding.
And it's doing that until all four drawing frames are updated.
Michel
8682.27 In reply to 8682.20
Hi Finema,
Are you sure that you are running the Nov 18 version, and not still running the older V4 version?
(Click on the Help button, lower left corner, then on the up arrow, to see the version running.)
8682.28 In reply to 8682.27
Yes Brian. I 'm sure it's the last one :)
EDITED: 9 May 2020 by FINEMA
8682.29 In reply to 8682.23
Hi Metin
>>A small update regarding Max's FatLines script
Also I updated subdiv tools, gear, nuts and bolt scripts.
I decided to not change script versions and release dates. Check all scripts which was uploaded in November 2017
http://moi.maxsm.net/files
EDITED: 7 Mar 2022 by SMIRNOV
8682.30 In reply to 8682.29
<< Check all scripts which was uploaded in November 2017
Good to know!
8682.31 In reply to 8682.29
Thank you very much Max for this update.
ASAP I will try the new versions with V4 and I will let you know.
Ciao.
What is the structure Folders / Files of the Max Smirnov Node Editor with the V4 inside the Moi Folders / Files itself?
8682.33 In reply to 8682.32
Hi Pilou, there is installation information for the node editor on the wiki here:
http://moi3d.com/wiki/Nodeeditor
You're supposed to copy the node editor folder inside of MoI's ui folder.
8682.34 In reply to 8682.33
Thx for the precision!
French Gear for V4 by Max Smirnov! (Windows 10)
http://moiscript.weebly.com/engrenages.html
EDITED: 21 Nov 2017 by PILOU
Glitch for Nuts & Bolts by Max Smirnov (V4) (Windows 10)
French SSPlit by Max Smirnov V4 (Windows 10)
http://moiscript.weebly.com/bridge.html
French version of the SBridge by Max Smirnov (V4) (Windows 10)
(easy: nothing to translate for this one! :)
8682.38 In reply to 8682.29
Many thanks for the updated versions of your scripts and commands, Max, your support to the MoI community is invaluable.
Regards,
Metin
visualization • illustration • animation • 3D (print) design — https://metinseven.com
8682.39 In reply to 8682.38
Hello.
...I've often wondered what would happen if Michael and Max were working together some day...
That could be great I think :)
Ciao!
Sorry need more infos about the Max Editor for the V4!
there is now editor.css & editor.js (edited in November)
so what is now the new structure and what put in this new structure?
UI/nodeeditor/ editor.css ...
or
UI/editor/ editor.css...
need more folders/files ?
or ...
What about nodeditor.zip of october?
I am in the fog! :)
8682.41
@ Marco: Max and Michael make a fine team indeed.
A little note regarding V4: I'm very happy that because of the native MacOS support I can finally use Default Folder X for fast access to favorite and recent folders. I really missed that in the WINE V3.
In case you're a Mac user too and don't know Default Folder X yet, I can heartily recommend it:
http://www.stclairsoft.com/DefaultFolderX/
It's created by a hard-working independent developer who provides excellent user support, like Michael.
Regards,
— Metin
8682.42
A little request:
Right now the MacOS MoI V4 beta doesn't allow keyboard shortcut columns to be resized in the Preferences. This results in unreadable entries like this:
In this case it's not visible which Numpad keys are assigned to the Boolean functions. As I use the keyboard shortcut list often as a reminder which keyboard shortcuts I've assigned to functions, I'd like to be able to resize the columns if that's not a hassle.
In case it's not difficult, I'd also welcome an alphabetical sort option when clicking on a column header.
I'll also post this in the V4 wishlist discussion.
Thanks in advance.
Regards,
— Metin
8682.43
I don't know if this has already been mentioned, but I noticed a bit of lag when dragging a selection range to select curve points in Show Points mode. The lag isn't there in the WINE V3.
— Edit: I also just noticed the lag when panning the viewport, with several curves and selected points visible.
I also noticed that when you drag across the radius input value field of a selected curve, if you touch the "Radius" text, it will change to Diameter while you're still dragging to select the value.
My system specs:
• iMac (27-inch, Late 2013)
• MacOS High Sierra, version 10.13.1
• Processor: 3.5 GHz Intel Core i7
• Memory: 16 GB 1600 MHz DDR3
• Graphics: NVIDIA GeForce GTX 780M 4 GB
• Wacom Intuos Pro tablet + pen, latest drivers
EDITED: 21 Nov 2017 by METINSEVEN
Show messages:  1-3  4-23  24-43  44-63  64-83  84-103  …  124-137
