V4 beta Nov-18-2017 available now
 1-11  …  92-111  112-131  132-137
8682.132
When I go to export a mesh (fbx) and I type in the angle it allows me to type it does not respond initially (going from 12 to 3 does nothing) I have to use the slider once (I slide it all the way to More polygons) to make the typed portion work. the typing portion will work independently after I use the slider the first time. If that makes sense. can anyone else see if that is the case for them as well?
thanks,
Val
8682.133 In reply to 8682.132
Hi Val, I can't seem to repeat the typed in angle not responding initially over here. What OS are you on, and what are you doing exactly, like do you click in the field and then start typing, do you use the number panel that pops up, or do you just type keystrokes without clicking anything first?
8682.134
sorry, win 10, Now I can't get it to repeat it myself. I had been able to repeat it before but then I closed everything down reopened the same file and now it works. If it happens again I will post what I do in more detail.
8682.135
Quick question, since beta is 64 bit and now it loads a very serious amount of CAD data, also exports impressive size obj's, now the speed of viewport is a serious bottleneck. I work in medical robotics company and our cad assets are pretty huge to say the least.
Any inside on view port performance future?
Roman
8682.136 In reply to 8682.135
Hi Roman, I do expect to do some work on viewport performance improvements once the v4 beta is stabilized and the few remaining missing v3 functions are implemented.
8682.137
Michael,
Tried again and got the error. I opened up moi made a sphere went to file/export save to a place the select the 12 (blue selection) and type in 3 over top and nothing happens. I then go and slide the slider over and it all works. I got it to do it three times in a row (closing moi and reopening it) before I typed this.
cheers,
Val
Show messages:  1-11  …  72-91  92-111  112-131  132-137
