V4 beta Nov-18-2017 available now
 1-3  …  64-83  84-103  104-123  124-137
8682.104 In reply to 8682.100
Hi Vladimir, thanks for reporting this bug and posting the crash report and image files, that helps a lot for tracking down the bug!
It looks like the crash has to do with MoI v4 not handling lower color depth images properly. I should be able to fix it but for the moment you can get these images to work ok in the current v4 beta by converting them to 24-bit images, currently they are 8-bit images. I've attached converted versions here that you should be able to use until the next beta release. Be careful to not download the thumbnail image from the attachment, you need to use something like "Save link as..." if you right-click on the thumbnail, if you just use "Save image as" it will probably download the small thumbnail instead of the full size image.
Thanks, - Michael
Size: 75.3 KB, Downloaded: 180 times, Dimensions: 1000x680px
Size: 110.8 KB, Downloaded: 180 times, Dimensions: 690x1000px
8682.105 In reply to 8682.102
Hi Finema.
Only these files result in an error. Maybe the files are bad. Crash has created a report that can be useful for Michael. Thanks for checking.
8682.106 In reply to 8682.105
Hi Vladimir, the images are not bad but they are a little unusual because they're stored at a lower color depth. It's that low color depth that MoI v4 isn't handling properly yet. I attached some replacement images above which should work ok until the next beta. The crash report is very useful, thank you for posting it and the images.
8682.107 In reply to 8682.104
Thank you Michael for the detailed answer, help and your wonderful program.
The SpurGearProfile script is faulty.
- B
I have nearly the same code in LogSpiral script, which works fine.
SpurGear may have a misplaced
 </div>
near the end of the .htm file?
EDITED: 25 Nov 2017 by BEMFARMER
8682.109 In reply to 8682.106
it seems that openFileStream / writeLine / readLine functions are using Western codepage instead of UTF8. Mac version only.
I attached a nod-file with russian characters. Nodeeditor can't read this file properly.
EDITED: 7 Mar 2022 by SMIRNOV
8682.110 In reply to 8682.109
Hi Max,
For the next beta I've converted the internals of openFileStream to use the Qt text stream functions, it should provide better consistency in unicode support like be able to detect any encoding signature at the start of the text file and use UTF-8 by default.
8682.111 In reply to 8682.110
Thank you! Could we expect a binary read/write functions in v4? ;)
8682.112 In reply to 8682.111
Hi Max, I'm not sure about that, there could be some complications like trying to send binary data back and forth using strings can run into problems with things like illegal character encoding sequences and 0 values being treated as end of string markers.
There is a new kind of "typed array" thing that's meant for working with binary data in JavaScript but the version of JavaScriptCore that MoI v4 is currently using doesn't seem to have it included in the JSC API yet. That might not be possible without updating to the latest QtWebKit which is unfortunately a highly time consuming job.
8682.113
Hi Michael.
Paste does not work from the context menu of the mouse.
Video attached.
Vladimir.
8682.114 In reply to 8682.113
Hi Vladimir,
> Video attached.
Thanks for reporting it - I've put it on my list and I'll look into it next week. It won't be fixed yet for the very next coming beta since I want to release one soon, hopefully later today.
8682.115 In reply to 8682.81
Hi Marc & Metin,
> On thing I noticed is the 'live' aspect of extrude seems slower in the Mac version than Windows.
I can see this here too, thanks for reporting it. I've got it on my list now and I'll look into it next week, it won't be fixed for the very next beta quite yet.
New version of CMorph by Max Smirnov
http://moi.maxsm.net/media/files/
V4 (Windows 10)
New version of NutsandBolts by Max Smirnov
V4 (Windows 10)
New Cloth for V4 by Max Smirnov
(V4 Windows 10) (was fine in the V3 with old version :)
EDITED: 26 Nov 2017 by PILOU
In the hope that the following will assist in bug hunting:-)
Besides the non-working SpurGearProfile script, the LogSkelion script, which permits selection of a center point, does not work.
Today I tried out the JacobianFunctionGraph script, which uses color (style) selection.
It gives a weird error,
ReferenceError: Can't find variable: font
Line 16, there is a {
g_style_index = 0;
} there.
(I removed the "curly brackets" { }, and it seems the g_style_index = 0 is the problem line.)
Also, Please note that the script JacobianFunctionGraph-copy does not load the copy, it loads the original, JacobianFunctionGraph, with Max's customUI.
Maybe it is a customUI problem. Wen the modified script was renamed JacobianFunctionGraphMOD, it loaded properly.
(I have "DisableFileCaching = y in MoI.ini.)
EDITED: 26 Nov 2017 by BEMFARMER
Just installed a Samsung 28", UHD 4K monitor, model UE510, 28."
The quality of the display is very nice.
8682.121 In reply to 8682.119
Hi Brian, re: JacobianFunctionGraph not working, it looks like when an exception occurs in script from the .htm file the display of the lines of code with the >>> marker in it is not accurate, so disregard that part of the error message in this case and only pay attention to the top that says "ReferenceError: Can't find variable: font".
I looked around and it seems that this function in _JacobianFunctionGraph.htm file is were the error is at, I've marked the use of setting properties on font but there does not seem to be any such object. Looks like font will be 'undefined' an you can't assign properties to 'undefined'. Maybe exceptions in .htm file code in V3 were silently ignored or something like that which is why it's different there:
		<script>
			function PopulateFonts( factory )
				var FontList = factory.getFonts();
				for ( var i = 0; i < FontList.length; ++i )
					var Option = document.createElement( 'option' );
					var FontName = FontList.item(i);
					Option.text = FontName;
					Option.value = FontName;
>>>>				font.add( Option, i );
				var InitFont = 'Arial';
				try
					var PrevFont = moi.command.getOption( 'Text.htmDefaultFont' );
					if ( PrevFont != '' )
						InitFont = PrevFont;
				catch(e) { }
>>>>			font.value = InitFont;
				text.style.fontFamily = InitFont;
			// Left out Initialize() and Shutdown() functions
		</script>
8682.122 In reply to 8682.119
Hi Brian, so re: JacobianFunctionGraph - it kind of looks like the entire PopulateFonts is maybe pasted in from a different command and shouldn't be in there at all? It seems to be referring to controls that are not in the .htm file. It looks like you can just remove it and remove the 2 calls to it in the .js file and then JacobianFunctionGraph appears to be working.
I guess probably in v3 the exception generated in the .htm code is silently eaten, as if there was a try/catch around the whole function.
8682.123
Frenchy Pilou
Fixed
Can't reproduce this error
>>New Cloth for V4
Lets wait for a new v4 beta
Show messages:  1-3  …  44-63  64-83  84-103  104-123  124-137
