Invisible Layers when opening 3dm from Rhino
All  1  2-4
8681.2
If I remember, block instances or polygonal data it wont show in Moi, maybe it's this.
Marc
8681.3 In reply to 8681.1
Hi Muha, yes it's likely what Marc writes above where your object is a block instance or mesh object. If it's a block instance you'll need to use the ExplodeBlock command in Rhino on it to convert it into a regular object before MoI will be able to see it. If it's a mesh object then it's a different type of data than what MoI works with.
8681.4
Good morning,
thank your for your answers and your help.
The needed part is a block instance.
Good to know that I need convert those instances into regular meshes.
Show messages: All  1  2-4
