V4 beta Nov-13-2017 available now
 1-13  …  154-173  174-193  194-213  214-231
8675.194 In reply to 8675.193
Hi JP, well that's pretty mysterious to me - over here I have tried using Cmd+H to hide it, then clicking on the dock icon to restore it and I can draw and click on things immediately after that. Tomorrow I'll try updating from 10.13.0 to 10.13.1 and see if that makes any difference.
Are you possibly running any utility or helper type programs that involve window handling?
8675.195 In reply to 8675.194
Micael
"Are you possibly running any utility or helper type programs that involve window handling?"
what do you mean ?
On Windows 7, with regular Logitech mouse, following JP's lead, there is a problem with using the Lightbulb icon in my taskbar.
Click lightbulb to open MoI v4, MoI works normally, draw a circle, square, etc.
Click lightbulb to "hide" v4.
Click lightbulb to "unhide" v4.
The dialog window in the upper righthand corner no longer functions. It is blank, or frozen depending upon state before hide/unhide.
Drawing tools do not work, unless I right click on the mouse.
Then a drawing tool can be clicked on, say circle, but menu expansion does not show, but the circle, can be drawn.
Unless a right click is done, another drawing tool cannot be selected, also if two drawing tools are selected, then right click is done,
the first one can be drawn.
There are some permutations. If a drawing tool was started before the hide/unhide occurs, it will work after unhide, but the dialog screen is frozen.
Sometimes planar works, or not.
Using the __ button in the upper right hand window has similar effect to clicking lightbulb in taskbar.
Using the change window size button (the overlapping squares in upper right hand corner of window,)
(Sometimes) RESTORES functioning.
(Sorry I do not know the names of all of the buttons or regions.)
8675.198 In reply to 8675.197
yes it's exactly what it's happen for me.
Please try :
1•Click lightbulb to open MoI v4, MoI works normally, draw a circle, square, etc.
2•Click lightbulb to "hide" v4.
3•Click lightbulb to "unhide" v4.
4•CLIC AGAIN ON LIGHTBULB and try to draw
thanks
8675.199 In reply to 8675.198
One more clue:
If I start from a NON-maximized MoI window, there is no problem.
(as far as I have minimally tested.)
- B
8675.200 In reply to 8675.199
Yes ! well done Brian
If i reduce the window there is no problem indeed.
Another very minor topic:
In v3, when I close a script, then do a right click, the script will repeat, using previously altered options from the dialog region, upper right corner.
In v4, after a script is closed, right click repeats the script, using original options.
Maybe a minor .ini setting?
EDIT, I may be PARTLY wrong in the above statements :-) (I'll do some more testing.)
ps, got a grid of Truchet tiles to work. (Script still needs some work.)
v4 is near instantaneous.
v3 is quite slow, due to .js as previously explained by MG.
EDITED: 18 Nov 2017 by BEMFARMER
8675.202 In reply to 8675.201
Brian,
i've tested with DistortCurves script and options changed are here
8675.203
Yes, now I am able to duplicate this 'freeze' problem.
Open MoI 4
Hide it using the - key in the upper right corner of the screen.
Open another program ... shut it down.
Bring MoI back to full screen by clicking on the MoI icon.
Commands are frozen.
Reduce MoI to part screen. Open it to full screen again.
Now it works.
For me this is intermittent. It does not happen each time I follow the same routine.
cheers,
eric
8675.204 In reply to 8675.202
Hi Finema,
I've edited my "repeating scripts vs options" post, as being partly wrong. :-)- Brian.
But partly right.
Using LineWeb as an example, MoI3 preserves Build options upon exit of command and right click.
MoI4 does not preserve Build options upon exit of command, and subsequent right click repeat of command, but does preserve closed checkbox.
8675.205
Running the latest v4 Beta Mac Version (on El Capitan, 10.11.6) when I create second window a new moi3d app is launched, Just checking this is not the expected behaviour ?
But the app is looking great on a retina Mac laptop.
Colin
8675.206 In reply to 8675.203
Seems a replicate variation of my freezing Moi / Forum / Moi! ;)
So I am not alone in the space! :D
http://moi3d.com/forum/index.php?webtag=MOI&msg=8675.103
EDITED: 18 Nov 2017 by PILOU
Hi Michael and everyone.
I can confirm the same issue raised by Finema :
I use Windows 10 Pro 64 Bit.
8675.208
I can also confirm finerma
dialog locks up after hiding/unhiding v4
I also use win 10 pro 64 bit
thanks,
Val
8675.209 In reply to 8675.205
All right, well that gives me some more things to try, and it's also interesting that the hide/show problem is cross platform as well.
8675.210 In reply to 8675.205
Hi Colin,
Yeah unfortunately this is going to be the way that I have to make it work. MoI expects that each main program window has its own thread and process but there isn't any way on Mac for multiple processes to share a single dock icon.
The way that Apple has implemented multiple windows in its standard application infrastructure is problematic because they have them all inside the same process and sharing a single UI thread which means they can interfere with each other in various ways. If one crashes for example they all crash because they aren't running in separate processes.
So this (multiple app windows) is an area where the standard Apple way is just not good and I don't expect to have MoI follow the standard behavior for this particular thing.
8675.211
I think someone mentioned this.
'Snaps' have stopped working for me ... and this seems to have migrated to V3.
mid, int, end etc have stopped working.
Windows 10 ..
eric
8675.212 In reply to 8675.211
Hi eric, are they all enabled on the menu? :
And object snap turned on (highlighted in orange on the main button) ?
Ok, I've finally been able to reproduce the UI freezing problem over here, seems to be easier to reproduce on Windows. When it happens it looks like clicks still do stuff but nothing visually updates. I'll be digging into it.
Show messages:  1-13  …  134-153  154-173  174-193  194-213  214-231
