V4 beta Nov-13-2017 available now
 1-8  …  149-168  169-188  189-208  209-228  229-231
8675.189 In reply to 8675.188
Michael
here a step by step :
Open MoI V4
Draw a rectangle for example (all is Ok, all the draw tools works)
Hide MoI (not quit)
Go the Finder or other apllications
Go back to MoI
Choose Rectangle tool or other draw tool
Clic to draw , drag have no effect
Result : no icon tool and panel stay empty (sse my screenshot)
Solution :
clic on Icon Moi V4 in the Apple Dock bar (click anywhere in the window don't work)
choose a draw tool
Bing ! i can draw again.
EDITED: 9 May 2020 by FINEMA
8675.190 In reply to 8675.189
Hi Finema, it sounds like we're getting closer but I still can't quite replicate it. Can you please be very specific about how you're doing the "Hide MoI" and "Go back to MoI" steps? I tried hiding MoI by clicking on the yellow button in the title bar, and going back to it by clicking on its icon in the right-hand side of the dock where it shrunk down to and I can't replicate a problem.
8675.191 In reply to 8675.190
Michael
If i hide MoI by clicking on the yellow button in the title bar and return to MoI > draw tool works
but :
Hide MoI > command H or clic on other appli in the Dock
return to MoI > Dock bar > clic on MoI v4
 draw tools don't works, i must clic again on MoI in the dock bar to give a focus
ps : i sent you the report of Monitor activity
EDITED: 18 Nov 2017 by FINEMA
8675.192 In reply to 8675.191
Hi Finema,
I don't see any text "MoI v4" in the dock bar over here, do you mean left click on the lightbulb icon in the dock bar?
When you see the problem does it look like the title bar of the MoI window is grayed out, are the 3 buttons on the left-hand side of the title bar showing colors or are they only showing gray? Also does the menu at the very top of the screen have "MoI v4 beta" on it or is it the menu for some other app?
8675.193 In reply to 8675.192
"do you mean left click on the lightbulb icon in the dock bar?" > yes
"are the 3 buttons on the left-hand side of the title bar showing colors or are they only showing gray" no colors on 10.13.1 > always grey (i never see colored icons on 10.13 high sierra
"Also does the menu at the very top of the screen have "MoI v4 beta" on it or is it the menu for some other app?" > always MoI v4 beta
8675.194 In reply to 8675.193
Hi JP, well that's pretty mysterious to me - over here I have tried using Cmd+H to hide it, then clicking on the dock icon to restore it and I can draw and click on things immediately after that. Tomorrow I'll try updating from 10.13.0 to 10.13.1 and see if that makes any difference.
Are you possibly running any utility or helper type programs that involve window handling?
8675.195 In reply to 8675.194
Micael
"Are you possibly running any utility or helper type programs that involve window handling?"
what do you mean ?
On Windows 7, with regular Logitech mouse, following JP's lead, there is a problem with using the Lightbulb icon in my taskbar.
Click lightbulb to open MoI v4, MoI works normally, draw a circle, square, etc.
Click lightbulb to "hide" v4.
Click lightbulb to "unhide" v4.
The dialog window in the upper righthand corner no longer functions. It is blank, or frozen depending upon state before hide/unhide.
Drawing tools do not work, unless I right click on the mouse.
Then a drawing tool can be clicked on, say circle, but menu expansion does not show, but the circle, can be drawn.
Unless a right click is done, another drawing tool cannot be selected, also if two drawing tools are selected, then right click is done,
the first one can be drawn.
There are some permutations. If a drawing tool was started before the hide/unhide occurs, it will work after unhide, but the dialog screen is frozen.
Sometimes planar works, or not.
Using the __ button in the upper right hand window has similar effect to clicking lightbulb in taskbar.
Using the change window size button (the overlapping squares in upper right hand corner of window,)
(Sometimes) RESTORES functioning.
(Sorry I do not know the names of all of the buttons or regions.)
8675.198 In reply to 8675.197
yes it's exactly what it's happen for me.
Please try :
1•Click lightbulb to open MoI v4, MoI works normally, draw a circle, square, etc.
2•Click lightbulb to "hide" v4.
3•Click lightbulb to "unhide" v4.
4•CLIC AGAIN ON LIGHTBULB and try to draw
thanks
8675.199 In reply to 8675.198
One more clue:
If I start from a NON-maximized MoI window, there is no problem.
(as far as I have minimally tested.)
- B
8675.200 In reply to 8675.199
Yes ! well done Brian
If i reduce the window there is no problem indeed.
Another very minor topic:
In v3, when I close a script, then do a right click, the script will repeat, using previously altered options from the dialog region, upper right corner.
In v4, after a script is closed, right click repeats the script, using original options.
Maybe a minor .ini setting?
EDIT, I may be PARTLY wrong in the above statements :-) (I'll do some more testing.)
ps, got a grid of Truchet tiles to work. (Script still needs some work.)
v4 is near instantaneous.
v3 is quite slow, due to .js as previously explained by MG.
EDITED: 18 Nov 2017 by BEMFARMER
8675.202 In reply to 8675.201
Brian,
i've tested with DistortCurves script and options changed are here
8675.203
Yes, now I am able to duplicate this 'freeze' problem.
Open MoI 4
Hide it using the - key in the upper right corner of the screen.
Open another program ... shut it down.
Bring MoI back to full screen by clicking on the MoI icon.
Commands are frozen.
Reduce MoI to part screen. Open it to full screen again.
Now it works.
For me this is intermittent. It does not happen each time I follow the same routine.
cheers,
eric
8675.204 In reply to 8675.202
Hi Finema,
I've edited my "repeating scripts vs options" post, as being partly wrong. :-)- Brian.
But partly right.
Using LineWeb as an example, MoI3 preserves Build options upon exit of command and right click.
MoI4 does not preserve Build options upon exit of command, and subsequent right click repeat of command, but does preserve closed checkbox.
8675.205
Running the latest v4 Beta Mac Version (on El Capitan, 10.11.6) when I create second window a new moi3d app is launched, Just checking this is not the expected behaviour ?
But the app is looking great on a retina Mac laptop.
Colin
8675.206 In reply to 8675.203
Seems a replicate variation of my freezing Moi / Forum / Moi! ;)
So I am not alone in the space! :D
http://moi3d.com/forum/index.php?webtag=MOI&msg=8675.103
EDITED: 18 Nov 2017 by PILOU
Hi Michael and everyone.
I can confirm the same issue raised by Finema :
I use Windows 10 Pro 64 Bit.
8675.208
I can also confirm finerma
dialog locks up after hiding/unhiding v4
I also use win 10 pro 64 bit
thanks,
Val
Show messages:  1-8  …  129-148  149-168  169-188  189-208  209-228  229-231
