V4 beta Nov-13-2017 available now
 1-4  …  125-144  145-164  165-184  185-204  205-224  225-231
8675.165 In reply to 8675.164
Hi Ralf
No, I can't zoom with magiMouse2
8675.166 In reply to 8675.165
Magic mouse not zooming is related to the trackpad view manipulating not being finished, I need to be able to figure out how to tell the difference between getting a trackpad scroll event or the magic mouse scroll event to get that fixed up.
8675.167 In reply to 8675.162
Hi eric - when you say the icons don't respond do you mean they are 100% completely dead and don't do anything whatsoever when you move your mouse over thtem, or is it more like the buttons show mouseover and click appearance but when you click them nothing happens?
Knowing that may help me to focus more on UI infrastructure or command-running infrastructure.
Thanks, - Michael
8675.168
Hi Michael.
The Rebuild Script.
In the field Tolerance default outputs 0, in v3 were 0,1.
8675.169 In reply to 8675.163
Hi Finema,
> I use a magic Mouse 2.
> But i've tested with a Magic Mouse (1) and i can't reproduce the bug.
Thanks for this information - I'll order a Magic Mouse 2 so I can test it over here. I'll have the best chance at fixing it if I can repeat it here.
8675.170 In reply to 8675.168
Hi Vladimir, so what's probably happening there is related to UI controls showing 2 decimal places of accuracy. The initial default for the Rebuild command tolerance is 0.01 which should display ok since it's only 2 decimal places. But if you type in something with more decimal places than that like 0.001 for example, then that will be the new default for any more runs of the command during this same modeling session but when that gets rounded to 2 decimal places for display it will show 0 . V3 should behave the same way.
I've been meaning to tune this up for some time, maybe one way it can work is if you enter in a value with more decimal places than the current display setting it should give more decimal places on that particular control so you won't see a rounded display value.
For the moment you can also bump up the default display precision under Options > General > Decimal display - set it to 1.000 with 3 zeros showing.
I'll try to get this tuned up for the next beta.
8675.171 In reply to 8675.170
Michael, thanks for the reply. This is the only problem, is corrected by manual input, overall the script works.
Let's wait for the hotfix, thanks again.
8675.172 In reply to 8675.168
Hi Vladimir
on my V4, Tolerance output 0,01
8675.173 In reply to 8675.167
Yes, Michael, they are completely dead at times. No response at all.
The mouse I use is a basic plain vanilla logitech wireless M560. No problem with V3.
cheers,eric
8675.174
Hi, I just booted this up and played for 10 minutes. Maybe its just me, but I cant see ANY noticeable difference between V3 and this version (apart from the viewports now have a number below their description which I don't understand). Is everything new under the hood or are there other changes? Are they listed somewhere?
Personally I'd like more ability to deform objects (like a freeform cage or something) so I can get 'closer' to organic modelling than is currently possible.
Simon
8675.175 In reply to 8675.174
It's just a version(s) for validate the 64 bits new paradigm! (Mac & PC)
As soon as all works fine, all new functions will be added! ;)
8675.176 In reply to 8675.174
Hi Simon, yes the differences for this version are all under the hood in the foundations. The main differences are that MoI is now a 64-bit program and on the Mac it's a native build rather than using the Wineskin system.
The 64-bit part means that MoI can now make use of all your system memory instead of only being able to use around 3.5 GB. For example if you were working on a large model in V3 and attempted to export it out to a mesh file format, you would easily run into an "Insufficient memory" error and you'd be unable to do the export. With v4 doing that same export won't run into that problem anymore. So it basically sets the stage for being able to use MoI with much more complex objects than before.
For the Mac there are other additional improvements, the "native Mac build" part means it's 64-bit there too and numerous glitches in things like general window sizing behavior won't be a problem anymore.
But yes if you're not working with large files and not working on the Mac there won't be anything really noticeable for v4 quite as of yet. That's actually why I put off this work for quite some time but the longer I put it off the harder it would become to make the switch over.
There are still a few details to finish up for the foundational work but then I will be shifting back to working on some more regular individual features rather than the foundational stuff.
8675.177
Great work as always! One thing though ... after running the beta, my v.3.1 (on Mac OS 10.12.1) is now displaying any UI fonts very course and bitmapped. It appears that there's no font smoothing being performed anymore.
Is there a way to bring it back for v.3.1? Thanks!
- Fabien
8675.178 In reply to 8675.176
First of all.. many many thank! Its so fast, so nice. Huge improvement.
A few things I found on OSX:
- The trackpad zoom is very very tiny. I set it multiply to 100 to even see it. However on larger models it get tiny again. So maybe you could make it more scene size dependent?
- Trackpad role doesn't work.. not so important. (Two finger turn, works in Blender).
- The Mesher in OBJ export doesn't remember the Angle after an export, so its set to default value again (12). Also it would be good to have these settings general saved, like last session or so.
8675.179 In reply to 8675.177
Hi Fabien,
It's probably the result of a bug in the v4 beta where it overwrites the UI font name property used by v3 in moi.ini - I had meant to keep them separate but made a mistake there.
To fix it, try copying your moi.ini file which is at ~/Library/Application Support/Moi/moi.ini into the Contents/Resources folder inside the v4 beta's app bundle. This should make the v4 beta use its own separate moi.ini file instead of the normal shared one.
Then edit your main moi.ini file and remove the UIFontName= line in the [UI] section. This should reset v3's font back to default.
This will be fixed up for the next v4 beta so v4 and v3 will use separate font name properties in moi.ini so it allows v4 to use a new font while still sharing other settings.
8675.180 In reply to 8675.178
Hi Robert, thanks for reporting these problems.
Does this only happen in the 3D perspective view or does it also happen in an ortho view?
I think you can enable a 2 finger turn under Options > View > MultiTouch options. You can set "Rotate ortho views" and/or "Allow 3D rotation tilt" there, does that do it?
Hmm, the way it's intended to work is that settings should be saved for any further exports in the same program session but not if you exit MoI and start a new session. You can enable settings persisting between sessions though by setting PersistSettingsBetweenSessions=y in the [Mesh Export] section of moi.ini .
8675.181 In reply to 8675.160
Hi Finema, I got a Magic Mouse 2 over here now and I've been testing with it but can't seem to repeat the problem of it getting stuck and not allowing to pick the other corner point in commands like rect or box. I'll keep trying but please let me know if you get any idea of when it might happen like if you think it might be if you were panning or dragging a construction line right then as well or whatever.
Thanks, - Michael
8675.182 In reply to 8675.181
It's randomly. Sometimes when i open moI V4, i can't draw shapes or solids.
it seems to be i haven't focus to draw, i haven't icon below the arrow for the Pick corner point.
note : when this happens, Grid snap and Object snap no longer works
JP
8675.183 In reply to 8675.182
in attachment , icon i could have when i take a tool to draw a shape or solid
EDITED: 9 May 2020 by FINEMA
8675.184 In reply to 8675.182
Hi JP,
Ok, this sounds a little different than what you were reporting before, when this happens you can't place even the first point in a draw command no matter how many times you try to run a drawing command? Are all commands like even File > Open also blocked or just drawing commands? In your original report it sounded like you could pick the first point but not the other corner point.
How often does it happen, like only once every hour, once every minute, ... ? Is it frequent enough that you're pretty sure it doesn't happen with your Magic Mouse 1 ?
Thanks, - Michael
Show messages:  1-4  …  105-124  125-144  145-164  165-184  185-204  205-224  225-231
