Hi Robert, thanks for reporting these problems.
> - The trackpad zoom is very very tiny. I set it multiply to 100 to even see it. However on larger
> models it get tiny again. So maybe you could make it more scene size dependent?
Does this only happen in the 3D perspective view or does it also happen in an ortho view?
> - Trackpad role doesn't work.. not so important. (Two finger turn, works in Blender).
I think you can enable a 2 finger turn under Options > View > MultiTouch options. You can set "Rotate ortho views" and/or "Allow 3D rotation tilt" there, does that do it?
> - The Mesher in OBJ export doesn't remember the Angle after an export, so its set to default value
> again (12). Also it would be good to have these settings general saved, like last session or so.
Hmm, the way it's intended to work is that settings should be saved for any further exports in the same program session but not if you exit MoI and start a new session. You can enable settings persisting between sessions though by setting PersistSettingsBetweenSessions=y in the [Mesh Export] section of moi.ini .
