V4 beta Nov-13-2017 available now
 1-7  …  108-127  128-147  148-167  168-187  188-207  …  228-231
8675.148 In reply to 8675.147
To me the beta does not work :(
Size: 38.7 KB, Downloaded: 53 times, Dimensions: 1051x610px
Message 8675.149 deleted 15 Nov 2017 by VKNW123
8675.150
nice.
how much will be an upgrade from v3?
8675.151
Thanks Michael G.!
Just curious, what do the numbers under the view name represent?
8675.152 In reply to 8675.151
quote:
The number up there is the amount of time in milliseconds it took for the last screen draw in that viewport. That will be up there for a while so it will be a little easier to measure display performance as more work is done in that area.
8675.153 In reply to 8675.152
8675.154 In reply to 8675.148
Hi Tony,
Can you please e-mail me the crash dump file, it looks like it was created at c:\Users\Antonio\AppData\Local\Temp\moi_report5.zip - there may be several there all named moi_report1.zip, moi_report2.zip , etc...
If you can e-mail those to me at moi@moi3d.com that give some information on what might be going wrong.
Hi VKNW123, I was just replying to your message about SelectByType not working - I guess you probably already found that it was a plug-in that you installed in V3 and so you need to also install it in V4 by copying it into the V4 commands directory.
8675.156 In reply to 8675.150
Hi glmr,
Currently it's planned to be the same as the V2 to V3 upgrade which is $100 USD.
8675.157 In reply to 8675.1
Hi Michael.
It's a miracle!! :)
The mysteries of life...
After only less than 3 days from the first V4 beta of Moi.....ta-ta!!! McNeil announces the final Beta Stage for Rhino V6 !!!!
What a timing :)
Another great "side effect" caused by Moi!!!
LOL :)
8675.158
I noticed that it was more fluid to create solids (sphere, box, plane) on the V3. There is a slight dead time between the first click and the second click on V4.
Also sometimes it is impossible to create the shape after the first click. Pick panel fields stay empty. (it happens randomly)
8675.159 In reply to 8675.158
Hi Finema, I can't seem to detect any sphere lag over here. I wonder if that and the other thing are related. What OS and type of mouse device do you use?
Can you describe the pick panel fields empty thing in a bit more detail, do you mean you start the sphere command and nothing at all shows for sphere in the upper right area of the window, does it just not change at all? Or something like it shows the first prompt but not the second prompt?
I wonder if it's getting stuck in something like a drag/drop.
Thanks - Michael
8675.160 In reply to 8675.159
my OS : Mac OS 10.13.1
mouse device : Magic Mouse 2
It happens sometines (randomly), when i want to create a sphere, plan, box, rect, etc..
Choose a tool
First Clic > Pick corner point panel appears
and after, drag/drop have no effect and Pick other corner panel (second prompt) stay empty and block.
EDITED: 9 May 2020 by FINEMA
8675.161 In reply to 8675.160
Hi Finema, do you possibly have any other mouse you could use to test with to see if it only happens with the magic mouse?
8675.162 In reply to 8675.160
Hi Michael ..
I may be experiencing something similar. Sometimes the UI icons don't seem to respond at all. It is random but once it is locked up it seems difficult to get a response. I'll start paying specific attention to see if I can describe when it happens.
Windows 10 Pro. HP mid tower, Intel 7, 16g ram.
eric
8675.163 In reply to 8675.161
Michael,
I use a magic Mouse 2.
But i've tested with a Magic Mouse (1) and i can't reproduce the bug.
8675.164 In reply to 8675.163
Can you zoom with your MagicMouse2?
I can only pan...
But your bug doesnt happen to me..
Ralf
8675.165 In reply to 8675.164
Hi Ralf
No, I can't zoom with magiMouse2
8675.166 In reply to 8675.165
Magic mouse not zooming is related to the trackpad view manipulating not being finished, I need to be able to figure out how to tell the difference between getting a trackpad scroll event or the magic mouse scroll event to get that fixed up.
8675.167 In reply to 8675.162
Hi eric - when you say the icons don't respond do you mean they are 100% completely dead and don't do anything whatsoever when you move your mouse over thtem, or is it more like the buttons show mouseover and click appearance but when you click them nothing happens?
Knowing that may help me to focus more on UI infrastructure or command-running infrastructure.
Thanks, - Michael
Show messages:  1-7  …  88-107  108-127  128-147  148-167  168-187  188-207  208-227  228-231
