V4 beta Nov-13-2017 available now
 1-18  …  99-118  119-138  139-158  159-178  179-198  …  219-231
8675.139 In reply to 8675.132
Hello Michael!
I'm glad to know that my tests are useful for you.
@You : "...It's looking like the transition to 64-bit and using a new cross platform graphics layer have not run into problems..."
Good. I understand your point of view.
A "no regression" it's kinda like a "foundation" :)
@You : "...Yup, ...it's something that I'll continue once things stabilize and reach full parity with V3...."
Perfect.
I'm pretty sure that this will be a "quantum leap" for Moi in general!
Leveraging on the modern GPU's power makes a huuuuuge difference :)
Ciao e grazie! (in Italian)
(Thanks!)
Marco (mkdm)
8675.140
I really miss the snap names when snapping (Mid, End, Int etc..)
Is there a way to get them back?
Thank you,
Max.
8675.141 In reply to 8675.139
Hi Marco,
Yup, that's it exactly.
8675.142 In reply to 8675.140
Hi Max,
They'll definitely be coming back but I still have some work to do for implementing them. It's one of just a couple still unfinished areas, it's not that they're just disabled by a setting or something like that. May be something like a couple more weeks before having these last pieces working again.
8675.143 In reply to 8675.142
Thanks!
8675.144 In reply to 8675.137
Thank you Michael.
I'll wait for Max's update. (The customui is working well in MoI4, as far as I can tell.) But meanwhile, I'll do some more
testing of my file copying (perceived) problem/confusion, with some more elaborate test names for *.js. (I'm using notepad++.)
(I've got 391 windows fonts installed, but do not see Open Sans.)
Hi Finema, thank you, but I'm on Windows7, customui is working, but I seem to have a problem with script file copying(?).
8675.145
I noticed that it was more fluid to create solids (sphere, box, plane) on the V3. There is a slight dead time between the first click and the second click on V4.
Also sometimes it is impossible to create the shape after the first click. Pick panel fields stay empty. (it happens randomly)
8675.146 In reply to 8675.138
Hi Finema,
the CustromUI runs so far and reacts as desired.
Unfortunately, however, no thumbnails are shown in the Obj Library.
Clicking on the saved. 3DM files does not load the models and new models cannot be saved.
The Ext Scripts window will open as expected - but some scripts won't run at all or abort with an error message.
The Snapshot function works like it should.
-moritz
8675.147 In reply to 8675.146
Hi Moritz
I only use Extscript, it's because i don't notice thumbnails error.
We are waiting for Max CustomUI update.
8675.148 In reply to 8675.147
To me the beta does not work :(
Size: 38.7 KB, Downloaded: 53 times, Dimensions: 1051x610px
Message 8675.149 deleted 15 Nov 2017 by VKNW123
8675.150
nice.
how much will be an upgrade from v3?
8675.151
Thanks Michael G.!
Just curious, what do the numbers under the view name represent?
8675.152 In reply to 8675.151
quote:
The number up there is the amount of time in milliseconds it took for the last screen draw in that viewport. That will be up there for a while so it will be a little easier to measure display performance as more work is done in that area.
8675.153 In reply to 8675.152
8675.154 In reply to 8675.148
Hi Tony,
Can you please e-mail me the crash dump file, it looks like it was created at c:\Users\Antonio\AppData\Local\Temp\moi_report5.zip - there may be several there all named moi_report1.zip, moi_report2.zip , etc...
If you can e-mail those to me at moi@moi3d.com that give some information on what might be going wrong.
Hi VKNW123, I was just replying to your message about SelectByType not working - I guess you probably already found that it was a plug-in that you installed in V3 and so you need to also install it in V4 by copying it into the V4 commands directory.
8675.156 In reply to 8675.150
Hi glmr,
Currently it's planned to be the same as the V2 to V3 upgrade which is $100 USD.
8675.157 In reply to 8675.1
Hi Michael.
It's a miracle!! :)
The mysteries of life...
After only less than 3 days from the first V4 beta of Moi.....ta-ta!!! McNeil announces the final Beta Stage for Rhino V6 !!!!
What a timing :)
Another great "side effect" caused by Moi!!!
LOL :)
8675.158
Show messages:  1-18  …  79-98  99-118  119-138  139-158  159-178  179-198  199-218  219-231
