Swap Pan And Zoom
All  1-3  4-7
867.4 In reply to 867.3
Hi Anthony, can you be more specific about what functions you want to swap?
The normal way to zoom with the mouse buttons is to spin the scroll wheel, and the normal way to pan is to hold down and drag the middle mouse button.
Since the scroll wheel only operates in one direction and pan is a 2-direction operation, it isn't possible to swap these functions and do a pan by spinning the mouse wheel.
But you may be talking about one of the other methods that I put in there to make things more compatible with some other systems, like holding down alt, etc... - if so then please let me know the details.
867.5 In reply to 867.4
Ooops, I meant to say swap pan and rotate. I simply want to swap the middle-mouse-button and the right-mouse-button.
867.6 In reply to 867.5
Hi Anthony, there isn't any way to do this in the current version, but I have added a switch to enable this in the next beta release which should be out probably later this week.
You'll have to edit the moi.ini file to set the switch, you can find moi.ini here:
C:\Documents and Settings\[ your login name ]\Application Data\Moi\moi.ini
It will be a new entry under the [View] section:
[View]
SwapPanRotateMouse=y
867.7 In reply to 867.6
Show messages: All  1-3  4-7
