Lots of unkown
 1-8  …  309-328  329-348  349-368  369-372
8665.349 In reply to 8665.347
Hi Tudor,
> will be good for next version - where will be point selection in scripting
> idea is simple
> whenever i've determined there's an arc or simple bended curve draw aids on corners as shown - pivot points on missing corners
Sorry I don't understand this at all. Are you looking for some way to make a point picker snap to those points you show?
What command is the point picker running in? Are you talking about a pointpicker in a new command you want to write or in an existing command?
8665.350 In reply to 8665.348
Hi Tudor,
> cylinder, cutted with a plane
> selecting cutted smaller piece top face - extrude -> no problems, with cutted in between, extrude -> slows down and shows artifacts, any scale
Can you please post a .3dm model file with the cut cylinder in it that you are seeing the artifacts with?
8665.351 In reply to 8665.350
extrude
- Tudor -
EDITED: 7 Nov 2021 by CEMORTAN_TUDOR
8665.352 In reply to 8665.349
snap yes
there's no easy easy other then build construction lines
move/rotate from corner point,scale/copy .. etc -> mostly for 3d view
- Tudor -
Size: 115.1 KB, Downloaded: 71 times, Dimensions: 731x466px
8665.353
another idea with arcs
polyline round corners -> add a snap point of last distance(red) on new drawn contruction line or holding shift snap line -> manual fillet or draw arcs
other words -> distance from a to b to project on b to c if it's a contruction line
Size: 22 KB, Downloaded: 73 times, Dimensions: 383x243px
8665.354 In reply to 8665.351
Hi Tudor,
> extrude
Thanks for posting the file. What piece should I select and extrude to see the artifacts that you were asking about?
8665.355 In reply to 8665.352
Hi Tudor,
> snap yes
No easy way to do what exactly? I'm sorry but I'm not getting enough information from you to be able to understand what you're asking about here.
8665.356
https://youtu.be/2txgDjHsXIc?t=950
another future that will benefit
offset extend to cap surface
- Tudor -
8665.357
external link, out of space https://www.sendspace.com/file/zara2u
any red/orange selection
- Tudor -
8665.358 In reply to 8665.355
i'll post geometry later where i see benefits
as more detailed explanation
- Tudor -
8665.359 In reply to 8665.357
Hi Tudor,
Thanks, I can repeat the extrude artifacts over here now. But they only seem to happen when the extrusion is a very small distance away. Once you move more than about 1 unit the artifacts disappear. Is it the same over there?
I think the artifacts are related to difficulty in doing boolean calculations on small slivery objects.
I might be able to improve this, I'll put it on my list of things to investigate. Thanks for sending it in.
8665.360
using rotate is possible to align parallel to one edge with one construction line, or ways todo it easier
- Tudor -
Size: 52.4 KB, Downloaded: 73 times, Dimensions: 1070x897px
8665.361 In reply to 8665.360
Hi Tudor, you can capture a direction with a construction line and relocate it to the rotation center, then use snaps.
Here's a demonstration:
8665.362
thanks !
- Tudor -
8665.363
using this script
moi.geometryDatabase.deselectAll();
var a = moi.command.lastCommandRevisionStart;
var b = moi.command.lastCommandRevisionEnd;
var objects = moi.geometryDatabase.getObjects();
for ( var i = 0; i < objects.length; ++i ) {
var obj = objects.item(i);
if ( obj.databaseRevision> a && obj.databaseRevision <= b ) obj.selected = true; }
akka: LastCreated Object/objects -> usefull to control arrays or booleans/new geometry/curves so on
& i have some troubles
1. If I'll move an object, scale, rotate - it will count as last object, not new one created(let's say I've created a circle before - and script will record last object as LastCreated)
2. after creation if i'll cancel next operation, it wount count as last created (ex: created circle, try to move, didn't like, cancel - Last created won't count any more, history gone)
good addition will be -> undo saves last created tree* -> after 10 creation & 6 undos, will selet '4th created
as i see this should be ~ history records on new created objects, correct me if it's not designed application
- Tudor -
8665.364 In reply to 8665.363
Hi Tudor,
Yes, this is the intended behavior. When you move, scale, or rotate an object the original object is deleted and a new one is created.
Yes this is also how it is intended to work. The "last created" information that you are gathering is what was created by the last command that was run.
If you run a command and then cancel it that was the last run command and it didn't create anything, so asking for what was created by the last run command should return nothing in this situation.
If those are not doing what you need then you'll need some other mechanism to do it, these are working as they are supposed to.
8665.365
in case like this where are 2 frames of curves - can't fillet the corners (orange/green, orange/blue)
defaults - i think that it should work like blend
- Tudor -
Size: 143.1 KB, Downloaded: 61 times, Dimensions: 936x884px
8665.366 In reply to 8665.365
Hi Tudor, can you please post the .3dm model file with that geometry in it?
8665.367 In reply to 8665.366
out of space, expand my inbox )))
https://easyupload.io/6wcc94
orange/greeen - for blend
orange/blue for fillet
- Tudor -
8665.368 In reply to 8665.367
Hi Tudor, thanks for posting the file. I was hoping that would help me understand what you are asking about but I'm afraid that I still don't understand.
Are you trying to fillet curves instead of edges?
Not understanding this either, do you mean you've already done a blend between orange and green and a fillet between orange and blue?
Sorry I'm not getting it, - Michael
Show messages:  1-8  …  289-308  309-328  329-348  349-368  369-372
