Lots of unkown
 1-18  …  279-298  299-318  319-338  339-358  359-372
8665.319 In reply to 8665.318
Hi Tudor, you can select faces that were created by the last run command by using this script in v4:
script: /* Select fillet surfaces */ moi.geometryDatabase.deselectAll(); var breps = moi.geometryDatabase.getLastCreated().getBReps();
for ( var i = 0; i < breps.length; ++i ) { var faces = breps.item(i).getFaces(); for ( var j = 0; j < faces.length; ++j )
{ var f = faces.item(j); if ( f.isNew ) f.selected = true; } }
So for example after doing a fillet that will select all the fillet surfaces.
8665.320 In reply to 8665.319
Cool !
And something for select only "Flat Faces" ? (not especially after the last function)
8665.321 In reply to 8665.320
Hi Pilou, planar faces can be selected using the detailed object properties dialog.
Select the solid first, then click "Details...", then click the label where it shows the number of faces, then click the label that shows the number of planar faces.
There will be another way in v5 using the Types section of the scene browser.
8665.322 In reply to 8665.321
Ah excellent i have totally forgotten this!
Idem
I forgot this possibility I knew.
But when I don't use it often, I forget to use this trick.
Thanks for this Michael !
8665.324
Ohayo
Is it possible to bind hotkeys to mouse 4/5 and combinations with those ?
~ default moi doesnt support that, any other softwares ?
- Tudor -
8665.325 In reply to 8665.324
Hi Tudor, sorry no MoI does not itself have any way to use extra mouse buttons.
Probably some kind of utility could be used for this, what operating system are you using?
8665.326 In reply to 8665.325
win 10
- Tudor -
8665.327 In reply to 8665.326
There's a utility program called AutoHotKey that can do that type of stuff.
8665.328
expanding boolDifference
1. for closed curves
if curves aren't on same frame(missdraw or random snap) will perform boolD to first plane
2. for selection of breps and curves, curves will be ignored - boolean will be applied only to breps
EDITED: 2 Nov 2021 by CEMORTAN_TUDOR
8665.329
fillet
c - swap between constant distance and circular
- Tudor -
8665.330
example of swapping from hard edge to soft(circular)
edge can be trimmed with a line, after chamfer - trimmed edges will remain & can be selected for next fillet
https://gifyu.com/image/eWdv
- Tudor -
8665.331
ohayo !
sweep question, how can a rect automatch a sweep profile ? or any other curved shape(planar) ?
panneling or border workflow
EDITED: 25 Oct 2021 by CEMORTAN_TUDOR
8665.332 In reply to 8665.331
Hi Tudor, I'm sorry I don't really understand the question. Are you asking about the "autoplace" mode for Sweep? That is turned on if a sweep profile is outside of the rail curve's bounding box. When it's on the sweep profile will be moved to the rail and rotated to align with the rail's tangent and then swept along the rail path.
If the profile curve is inside the bounding box of the rail curve then it will not be moved and will be swept from it's current position.
8665.333
run out of forum's disc space, outside link
https://easyupload.io/bloyl4
~ if combined with object library I could easily define border/paneling options
- Tudor -
8665.334
~ for implementation
when "transform tool" is enabled and picking from corner to scale -> option to rotate from that view -> ctrl + shift is still free
and a question -> is it possible to activate transform rotate tool from 3d view ?
8665.335 In reply to 8665.334
Hi Tudor,
Sorry I'm not understanding this request. Ctrl+shift is currently used to force window selection without any click selection.
If you have a planar object selected you can see the rotation grip in the 3d view and click it to turn on wheel mode. But otherwise no.
8665.336
as soon as red -> corner is activated - option for green - "ctrl + shift" rotation transform from that corner
- Tudor -
Size: 18.2 KB, Downloaded: 77 times, Dimensions: 589x387px
8665.337
extend working only in 1 direction
- Tudor -
8665.338 In reply to 8665.336
Hi Tudor,
The corner grips are used for scaling, rotation is done by the rotation grip. If you click on the rotation grip to activate wheel mode you can drag the rotation center point to a different location.
Show messages:  1-18  …  259-278  279-298  299-318  319-338  339-358  359-372
