Lots of unkown
 1-7  …  268-287  288-307  308-327  328-347  348-367  368-372
8665.308 In reply to 8665.307
Hi Tudor, it looks like maybe the object is inside-out. Try selecting it, then run Edit > Separate followed by Edit > Join. That seems to get its orientation set up ok.
Also your object is at a very small scale of only 0.02 units across. Try scaling it up by 100 times before meshing it, that will avoid some points from getting merged together.
8665.309
constant fillet fails on curves and not on surfaces, weird
- Tudor -
8665.310 In reply to 8665.309
Hi Tudor,
Prior to v4, constant radius fillet was not available for curves at all, as of v4 it works on line segments:
https://moi3d.com/wiki/V4Beta#Feb-27-2019
quote:
Update curve filleting - Enable "Constant distance" fillet mode for curves, currently only works for line segments.
8665.311
could be implemented in next version ?
- Tudor -
8665.312 In reply to 8665.311
Hi Tudor,
Sorry, no probably not, it's not supported by the geometry library currently.
8665.313
can't find script for "select similar edge length"
- Tudor -
8665.314 In reply to 8665.313
Hi Tudor,
Is it one in this thread? :
http://moi3d.com/forum/lmessages.php?webtag=MOI&msg=8905.1
8665.315
not quite that i'm searching for
there's a filter for curves biggest, smallest, or min/max , but I'm searching for edges
example - extrude taped, select one side edge of taped - run the script -> fillet/chamfer
or draw a rectangle, extrude by x amount, select 1 edge of height - run the script, or select the edge of original rectangle run the script
i've forgot lots of moi's scripting
select desired edge
moi.geometryDatabase.getSelectedObjects().getEdges().item(0).getLength(); get's edge selection length
get parent object(want only for current selection, in case there are duplicates of same object), get edges, loop through edges, if there's similar length - select
or if i Have a selected edge how can i get object numEdges count for the loop
by my understanding it should be ~ moi.geometryDatabase.getSelectedObjects().getTopLevelObjects().item(0).getEdges().numEdges
moi.geometryDatabase.getSelectedObjects() -> selected
.getTopLevelObjects() -> object itself
.item(0) - object nr
.getEdges() - all the edges
.numEdges - count edges
that doesn't work
EDITED: 7 Aug 2021 by CEMORTAN_TUDOR
8665.316 In reply to 8665.315
Hi Tudor, the problem in your script there is this part:
All the " getXXXXX()" methods on an object list do are filtering mechanisms, they make a new list that only contains the given types that are already present in the current list.
So if you had an object list with 2 objects in it, an edge and a brep, when you call getTopLevelObjects() it would return a list with just the brep in it, that's the only top level object currently in the list.
If you have an object list with just one edge in it, calling getTopLevelObjects() on it will return an empty list because there are no top level objects directly in the list currently.
You need to instead do something like this:
var objs = moi.geometryDatabase.getSelectedObjects(); if ( objs.numEdges == 1 ) { var edge = objs.item(0); var edges = edge.getParentBRep().getEdges(); moi.ui.alert( edges.length); }
So get the edge object, call getParentBRep() on it to get the parent brep, then call getEdges() on that.
8665.317
thanks !
/* select similar length edge*/
var edgeSelected = moi.geometryDatabase.getSelectedObjects().getEdges().item(0).getLength();
var tollerance = 1000;
var edgeL = objs.item(0).getLength();
var min = edgeL - edgeL/tollerance;
var max = edgeL + edgeL/tollerance;
for ( var i = 0; i < edges.length; ++i ) {
var edgeLoopL = edges.item(i).getLength();
if ( edgeLoopL> min && edgeLoopL< max)
edges.item(i).selected = true;
- Tudor -
8665.318
idk if fillets will be changed for v5
~ an addition - last created on fillet failed, but building the supported faces - to select new created faces
- Tudor -
8665.319 In reply to 8665.318
Hi Tudor, you can select faces that were created by the last run command by using this script in v4:
script: /* Select fillet surfaces */ moi.geometryDatabase.deselectAll(); var breps = moi.geometryDatabase.getLastCreated().getBReps();
for ( var i = 0; i < breps.length; ++i ) { var faces = breps.item(i).getFaces(); for ( var j = 0; j < faces.length; ++j )
{ var f = faces.item(j); if ( f.isNew ) f.selected = true; } }
So for example after doing a fillet that will select all the fillet surfaces.
8665.320 In reply to 8665.319
Cool !
And something for select only "Flat Faces" ? (not especially after the last function)
8665.321 In reply to 8665.320
Hi Pilou, planar faces can be selected using the detailed object properties dialog.
Select the solid first, then click "Details...", then click the label where it shows the number of faces, then click the label that shows the number of planar faces.
There will be another way in v5 using the Types section of the scene browser.
8665.322 In reply to 8665.321
Ah excellent i have totally forgotten this!
Idem
I forgot this possibility I knew.
But when I don't use it often, I forget to use this trick.
Thanks for this Michael !
8665.324
Ohayo
Is it possible to bind hotkeys to mouse 4/5 and combinations with those ?
~ default moi doesnt support that, any other softwares ?
- Tudor -
8665.325 In reply to 8665.324
Hi Tudor, sorry no MoI does not itself have any way to use extra mouse buttons.
Probably some kind of utility could be used for this, what operating system are you using?
8665.326 In reply to 8665.325
win 10
- Tudor -
8665.327 In reply to 8665.326
There's a utility program called AutoHotKey that can do that type of stuff.
Show messages:  1-7  …  248-267  268-287  288-307  308-327  328-347  348-367  368-372
