Lots of unkown
 1-15  …  256-275  276-295  296-315  316-335  336-355  356-372
8665.296
http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.141
earlier idea for moi, realization in blender -> intuitive
moi doesn't have pie menu, but it could have some after shortcuts, s for align, and s + w -> top , s + d -> right, s +a -> left, s + s -> down
ps: i wans't in blender when i've posted
in blender it's must to have for hard surface, anyway up to scripting moi's "point's scriptable" won't be reason to implement
- Tudor -
8665.297
some futures that i'd like to have inside moi
towards 2d workflow*
recently i was studying marvelous designer & captures will be from there
fillets/chamfers - at least 2d should be interactive
1. fillets radius - awesome visualization, ai should be similar
- Tudor -
Size: 381.7 KB, Downloaded: 88 times, Dimensions: 645x476px
8665.298
another awesome future ! MD
smooth curve - could be applied to any closed curve
select 2 points, select part that u wanna cut, adjust curvature
- Tudor -
Size: 1.1 MB, Downloaded: 101 times, Dimensions: 645x476px
Message 8665.299 deleted 19 Jul 2021 by CEMORTAN_TUDOR
8665.300 In reply to 8665.298
Hi Tudor,
If you want a smooth curve it's kind of strange to start out with a rectangle instead of just drawing a smooth curve right from the start.
But you can do something similar in Moi if you want, draw in a line, use the Trim command cut away the part you don't want, then use Edit > Add pt to add a point to the middle of the line and turn on edit points and adjust the point.
Adding in a special tool to do that would not be good, that's exactly how bloat happens.
I do have some ideas for having different draw modes to make draw commands intersect and cut away pieces without needing to do a separate Trim step.
8665.301
mb it was such a script made, polyline with offset, wanna combine in polyline option (pressing O)
EDITED: 20 Jul 2021 by CEMORTAN_TUDOR
8665.302
PolyCut updated, solved random issues
select one curve/solid - run the script
will change perspective to isometric
1. for solids/breps -> works in all views
2. curves - only in orto (moi doesn't perform booleans of random plane/frame curves)
right click to close the curve, or u can close manually
- Tudor -
8665.303
select last created is not working after deleting any object
- Tudor -
8665.304 In reply to 8665.303
Hi Tudor,
Yes that's normal. Select last created (by using moi.geometryDatabase.selectLastCreated();) selects whatever geometry was created by the last run command.
When you run the Delete command, that becomes the last run command and so then select last created will select whatever was created by the Delete command which will be nothing if you deleted an entire object, but other cases like the result of deleting only some faces or control points will be selected.
8665.305
any tips how to use shrink trimmed surface, or where it can be used ?
- Tudor -
8665.306 In reply to 8665.305
Hi Tudor, if you start with a complex surface and then boolean or trim away a large portion of it:
the original full surface is still there as the "underlying surface":
If you apply ShrinkTrimmedSrf to this, it will shrink down the underlying surface and cut out areas outside of the trim curve boundaries:
This can reduce surface complexity in cases like this and sometimes there can be problematic things like self intersections in other areas of the underlying surface that could interfere with some kinds of calculations.
Usually it is good to keep the full original surfaces because it makes repair operations by untrimming easier but if it's a very complex surface it can carry a lot of data size.
8665.307
problems with export as fbx/obj
fillets are not native
- Tudor -
8665.308 In reply to 8665.307
Hi Tudor, it looks like maybe the object is inside-out. Try selecting it, then run Edit > Separate followed by Edit > Join. That seems to get its orientation set up ok.
Also your object is at a very small scale of only 0.02 units across. Try scaling it up by 100 times before meshing it, that will avoid some points from getting merged together.
8665.309
constant fillet fails on curves and not on surfaces, weird
- Tudor -
8665.310 In reply to 8665.309
Hi Tudor,
Prior to v4, constant radius fillet was not available for curves at all, as of v4 it works on line segments:
https://moi3d.com/wiki/V4Beta#Feb-27-2019
quote:
Update curve filleting - Enable "Constant distance" fillet mode for curves, currently only works for line segments.
8665.311
could be implemented in next version ?
- Tudor -
8665.312 In reply to 8665.311
Hi Tudor,
Sorry, no probably not, it's not supported by the geometry library currently.
8665.313
can't find script for "select similar edge length"
- Tudor -
8665.314 In reply to 8665.313
Hi Tudor,
Is it one in this thread? :
http://moi3d.com/forum/lmessages.php?webtag=MOI&msg=8905.1
8665.315
not quite that i'm searching for
there's a filter for curves biggest, smallest, or min/max , but I'm searching for edges
example - extrude taped, select one side edge of taped - run the script -> fillet/chamfer
or draw a rectangle, extrude by x amount, select 1 edge of height - run the script, or select the edge of original rectangle run the script
i've forgot lots of moi's scripting
select desired edge
moi.geometryDatabase.getSelectedObjects().getEdges().item(0).getLength(); get's edge selection length
get parent object(want only for current selection, in case there are duplicates of same object), get edges, loop through edges, if there's similar length - select
or if i Have a selected edge how can i get object numEdges count for the loop
by my understanding it should be ~ moi.geometryDatabase.getSelectedObjects().getTopLevelObjects().item(0).getEdges().numEdges
moi.geometryDatabase.getSelectedObjects() -> selected
.getTopLevelObjects() -> object itself
.item(0) - object nr
.getEdges() - all the edges
.numEdges - count edges
that doesn't work
EDITED: 7 Aug 2021 by CEMORTAN_TUDOR
Show messages:  1-15  …  236-255  256-275  276-295  296-315  316-335  336-355  356-372
