Lots of unkown
 1-14  …  235-254  255-274  275-294  295-314  315-334  …  355-372
8665.275
ohayo
dragging points from a curve doesn't snaps to points of the same curve
- Tudor -
8665.276 In reply to 8665.275
Hi Tudor,
Yes, that's intentional to avoid having consecutive points get stacked up on top of each other too easily, such stacking degrades some of the mathematical properties of the curve and can cause problems.
8665.277
ohayo !
have a rectangle, wanna draw a small chamfer - at a good zoomout.
Q: It impossible draw without disabling snapping ? i'm asking about an option for snap distance !
- Tudor -
8665.278
Trim
t - trim add point
s - trim single segment ( can crash if not selected from object that was separated, idk how to fix)
added
c - join curves after deleting unwanted segments
- Tudor -
8665.279
fixed UnionJoin script
earlier opened surfaces where duplicating
- Tudor -
8665.280 In reply to 8665.279
Have you somewhere a repository of all your cool things ?
8665.281 In reply to 8665.277
Hi Tudor,
> ohayo !
In general it's difficult to work on something where you're zoomed out so that it is too small on screen. It's good to zoom in in such situations so you have some room on screen to work with.
There is a setting though for how far your mouse cursor needs to be from a snap point for the snap to engage, that's under Options > Snaps > Object snap options > "Snap radius".
8665.282
i might forgot, but this should work after copy/paste with coordinate frame
moi.ui.alert(moi.ui.getLastOrientationPickerFrame().origin.x)
- Tudor -
8665.283
1. construction lines + align on surface + rect center
drag construction lines & place the first point, second point I think should be autoaligned to surface
2. pointpicker.addSnapPoint( startpt, moi.ui.getText('Closed') ) I dont see text toolbox- is any trick behind
- Tudor -
Size: 169.5 KB, Downloaded: 85 times, Dimensions: 853x858px
8665.284 In reply to 8665.283
Hi Tudor, re: #2:
When you call moi.ui.getText( 'textid' ); that looks up text in the current language's string table for the text of the given id value.
There is no id value for "Closed" so your call there is going to return an empty string.
To fix it you could just pass some text directly instead of calling moi.ui.getText(), or use a valid textid like 'Closed snap'.
8665.285 In reply to 8665.283
Hi Tudor,
It's a bug where snap plane alignment is not happening when the base point is on a center object snap. I've got it on my list to get fixed up for v5.
8665.286
ohayo !
Wanna ask if in cad is such thing like keep same edge fillet distance (similar to subd will be bevel). I know there's pipe and cut, blend surfaces, but can this be done automatically ?
left - current fillet, right- desired
- Tudor -
Size: 106.2 KB, Downloaded: 88 times, Dimensions: 841x345px
8665.287 In reply to 8665.286
Hi Tudor, try the "constant distance" type fillet shape.
The regular one called a "rolling ball" fillet generates arcs all of the same radius, with the arc length being longer or shorter depending on the angle between surfaces.
The constant distance method makes the fillet rails to be a given distance apart from each other instead.
8665.288
it very often fails
- Tudor -
8665.289 In reply to 8665.288
Hi Tudor, yes unfortunately it's a pretty buggy area in the geometry library. It should work on the type of case that you showed though:
8665.290
ohayo
curves/lines -> merge. It should cut objects like one with circle, it doesn't
- Tudor -
Size: 53.8 KB, Downloaded: 93 times, Dimensions: 2187x619px
8665.291 In reply to 8665.290
Hi Tudor, boolean difference seems to do what you want on #3 and #4, but seems to be buggy on #1 and #2, I'll put it on my list to investigate.
8665.292
is it possible when exporting to have a specific folder(now it exports at saved file location) ?
- Tudor -
8665.293 In reply to 8665.292
Hi Tudor,
Sorry I don't understand the question, can you please describe it with a little more detail?
Thanks, - Michael
8665.294
let's say I have folder on c:/moi_proj where are all moi projects
& have second - bridge folder, that will be on d:/bridge
moi now is configured to save & exports at same file location, and it will be on c:/moi_proj
i'm asking for export location folder → d:/bridge, or even further export by last export type format(fbx/step) → that will be d:/bridge/fbx or d:/bridge/step
- Tudor -
Show messages:  1-14  …  215-234  235-254  255-274  275-294  295-314  315-334  335-354  355-372
