Lots of unkown
 1-20  …  201-220  221-240  241-260  261-280  281-300  …  361-372
8665.241 In reply to 8665.238
@ Michael : why we can't retake the first vertical line as Base Line for the Flow Function ?
You can, but it's a little difficult to select it since it's in the same location as a surface edge and the edge is getting priority.
Use Edit > Hide to hide the surface so you can then click select the first vertical line for the Flow base line.
8665.242 In reply to 8665.241
Thx for the Info!
I was not enough perceiving! :)
EDITED: 29 Aug 2020 by PILOU
8665.243
ohayo !
Michael how can I add a script page to show last updates of scripts (remove history tabs) or better will be github ?
- Tudor -
8665.244 In reply to 8665.243
Hi Tudor, you could make a post here in the forum and then link to the forum thread. Github is a good idea too though.
8665.245
rectangle interactive
the idea is to combines all rectangles under one shortcut and switch between them from hotkeys
q rect
w rect center
e rect 3pt
r - will be added - http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.164 -> rect with 3ptcenter ~ another way to grow new rectangles
script is unfinished
- Tudor -
8665.246 In reply to 8665.245
Hi Tudor.
Only one rectangle ;-)
EDITED: 30 Sep 2020 by WN
Size: 26.9 KB, Downloaded: 73 times, Dimensions: 276x245px
8665.247
looks a like a runtime error, I dont have it !
it's about moi version or smt else not related to the script
or it might ask for html .. that I havent work on, try to add if it works
EDITED: 30 Sep 2020 by CEMORTAN_TUDOR
8665.248 In reply to 8665.247
Hi Tudor.
Ok!
8665.249
Ohayo
will be possible to improve antialiasing on plane surfaces ?
- Tudor -
8665.250 In reply to 8665.249
Hi Tudor,
> Ohayo
Not for v4 but possibly at some point down the road.
8665.251
Thnkas !
& I have one more modeling challange ! I was looking around moi todo it
It's a new year toy that has to be twisted ~~~ I gave up doing in moi
- Tudor -
Size: 203.8 KB, Downloaded: 77 times, Dimensions: 463x745px
8665.252 In reply to 8665.251
Hi Tudor, maybe try the Transform > Deform > Twist command for that. Something like this:
8665.253
no control over twist, and ~ the countour that i need ~ misses the uv
- Tudor -
Message 8665.254 deleted 31 Oct 2020 by CEMORTAN_TUDOR
8665.255
any way that fillet g1-g3 could have a second slider for adjusting scaling*?
- Tudor -
Size: 56.8 KB, Downloaded: 85 times, Dimensions: 1052x800px
8665.256 In reply to 8665.255
Hi Tudor,
There isn't any way to set that up now but I would I would like to give some attention to Blend in the future and that is one of the things that I would like to do. Bring it up again when the v5 beta is underway.
8665.257
discovered smt new today !
if curves are mirrored & attach each other -> they can extrude a solid object without union ! neat !
- Tudor -
8665.258
hotkeys
add point
c - close curve
d - delete corners
- Tudor -
8665.259
Hi Michael, I've made gif vods of my scripts -> got error
The page was not displayed because the request entity is too large.
- Tudor -
8665.260 In reply to 8665.259
Hi Tudor, can you show a screenshot of the exact error message?
Show messages:  1-20  …  181-200  201-220  221-240  241-260  261-280  281-300  301-320  …  361-372
