Lots of unkown
 1-15  …  196-215  216-235  236-255  256-275  276-295  …  356-372
8665.236 In reply to 8665.235
you can also explore placing a centerline up a helix, then lofting the 2. Shell the result and pipe the centerline with what you wish.
So easier to create the 2 curves and flow those into a shape, that can then be made into a solid with the other steps.
8665.237 In reply to 8665.236
))) can u make a gif for that ! I'd appreciate 3'd method
- Tudor -
8665.238 In reply to 8665.237
From Burmann method :)
Draw an Arc-cicle for the future Flow
Draw a vertical line, Draw an Helix,
Loft them
Draw another vertical Line
Call Flow
Select Surface
Select Second vertical Line , Select Arc Line
Flow
@ Michael : why we can't retake the first vertical line as Base Line for the Flow Function ?
PS
I have forgotten to make a Tube but that is trivial :)
and a Shell but that will be exactly the same except a thickness to the Helicoïd surface! :)
EDITED: 27 Aug 2020 by PILOU
8665.239 In reply to 8665.238
Doing the surface creation and shelling "after" tge flow, allows me to monitor the validity of the solid better. I would expect the loft or shell to fail if i had created a "to tight to bend" situation, where flowing the solid result, could more easily allow me to create some type of "bad" geometry (folding over on itself, etc.)
8665.240
u are moi monsters, perfect results !
thanks !
- Tudor -
8665.241 In reply to 8665.238
You can, but it's a little difficult to select it since it's in the same location as a surface edge and the edge is getting priority.
Use Edit > Hide to hide the surface so you can then click select the first vertical line for the Flow base line.
8665.242 In reply to 8665.241
Thx for the Info!
I was not enough perceiving! :)
EDITED: 29 Aug 2020 by PILOU
8665.243
ohayo !
Michael how can I add a script page to show last updates of scripts (remove history tabs) or better will be github ?
- Tudor -
8665.244 In reply to 8665.243
Hi Tudor, you could make a post here in the forum and then link to the forum thread. Github is a good idea too though.
8665.245
rectangle interactive
the idea is to combines all rectangles under one shortcut and switch between them from hotkeys
q rect
w rect center
e rect 3pt
r - will be added - http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.164 -> rect with 3ptcenter ~ another way to grow new rectangles
script is unfinished
- Tudor -
8665.246 In reply to 8665.245
Hi Tudor.
Only one rectangle ;-)
EDITED: 30 Sep 2020 by WN
Size: 26.9 KB, Downloaded: 73 times, Dimensions: 276x245px
8665.247
looks a like a runtime error, I dont have it !
it's about moi version or smt else not related to the script
or it might ask for html .. that I havent work on, try to add if it works
EDITED: 30 Sep 2020 by CEMORTAN_TUDOR
8665.248 In reply to 8665.247
Hi Tudor.
Ok!
8665.249
Ohayo
will be possible to improve antialiasing on plane surfaces ?
- Tudor -
8665.250 In reply to 8665.249
Hi Tudor,
> Ohayo
Not for v4 but possibly at some point down the road.
8665.251
Thnkas !
& I have one more modeling challange ! I was looking around moi todo it
It's a new year toy that has to be twisted ~~~ I gave up doing in moi
- Tudor -
Size: 203.8 KB, Downloaded: 77 times, Dimensions: 463x745px
8665.252 In reply to 8665.251
Hi Tudor, maybe try the Transform > Deform > Twist command for that. Something like this:
8665.253
no control over twist, and ~ the countour that i need ~ misses the uv
- Tudor -
Message 8665.254 deleted 31 Oct 2020 by CEMORTAN_TUDOR
8665.255
any way that fillet g1-g3 could have a second slider for adjusting scaling*?
- Tudor -
Size: 56.8 KB, Downloaded: 85 times, Dimensions: 1052x800px
Show messages:  1-15  …  176-195  196-215  216-235  236-255  256-275  276-295  296-315  …  356-372
