Lots of unkown
 1-8  …  189-208  209-228  229-248  249-268  269-288  …  369-372
8665.229 In reply to 8665.228
Generally when you use the Sweep function it's a good thing to put 2 rails for control each side of the profil on the Helix...
EDITED: 25 Aug 2020 by PILOU
8665.230 In reply to 8665.228
Hi Tudor, I think you want the "Twist = Flat" option and also use "Set flat direction" along your axis:
The "Twist = Flat" option means the profile will not rotate freely around the rail tangent, it will be limited to only pivot around the "flat direction".
The default "Flat direction" is the world z axis, so when you have some other direction you need to click "Set flat direction" to set it.
Another way you can make this kind of thing is by extruding your profile out straight and then use Transform > Deform > Twist on it.
8665.231 In reply to 8665.229
@PILOU
i need Mike result, the way u are showing come to same issue that I have
8665.232 In reply to 8665.230
@Michael Gibson
I haven't used twist modifier so deeply, can u explain step by step how I can reach such result ?
mb gif animation
8665.233 In reply to 8665.232
Hi Tudor, the Twist way goes like this - you start out with a straight extrusion:
Select the straight extursion block and then run Transform > Deform > Twist .
At the prompts where it asks you for the start and end point of the twist access, pick these 2 points on your cylinder's axis:
Then you input an angle value, each 360 degrees will be one turn, so you could type in 5*360 to do 5 turns for example:
8665.234 In reply to 8665.232
Will be the same with only one turn...depending of what result you want...
In fact the "Flat Direction"
= the Rotation of the Profil depending of it's original position: the Flat Direction change artificially it's position! :)
Here Horizontal or Vertical
A Twist or a Sweep to an Helix will give the same result...in this case...
8665.235
thanks both !
I always tried to avoid twist or flow, unpredictable results .. Boolean or fillets could not execute (since v3 haven't tried new ones)
- Tudor -
8665.236 In reply to 8665.235
you can also explore placing a centerline up a helix, then lofting the 2. Shell the result and pipe the centerline with what you wish.
So easier to create the 2 curves and flow those into a shape, that can then be made into a solid with the other steps.
8665.237 In reply to 8665.236
))) can u make a gif for that ! I'd appreciate 3'd method
- Tudor -
8665.238 In reply to 8665.237
From Burmann method :)
Draw an Arc-cicle for the future Flow
Draw a vertical line, Draw an Helix,
Loft them
Draw another vertical Line
Call Flow
Select Surface
Select Second vertical Line , Select Arc Line
Flow
@ Michael : why we can't retake the first vertical line as Base Line for the Flow Function ?
PS
I have forgotten to make a Tube but that is trivial :)
and a Shell but that will be exactly the same except a thickness to the Helicoïd surface! :)
EDITED: 27 Aug 2020 by PILOU
8665.239 In reply to 8665.238
Doing the surface creation and shelling "after" tge flow, allows me to monitor the validity of the solid better. I would expect the loft or shell to fail if i had created a "to tight to bend" situation, where flowing the solid result, could more easily allow me to create some type of "bad" geometry (folding over on itself, etc.)
8665.240
u are moi monsters, perfect results !
thanks !
- Tudor -
8665.241 In reply to 8665.238
You can, but it's a little difficult to select it since it's in the same location as a surface edge and the edge is getting priority.
Use Edit > Hide to hide the surface so you can then click select the first vertical line for the Flow base line.
8665.242 In reply to 8665.241
Thx for the Info!
I was not enough perceiving! :)
EDITED: 29 Aug 2020 by PILOU
8665.243
ohayo !
Michael how can I add a script page to show last updates of scripts (remove history tabs) or better will be github ?
- Tudor -
8665.244 In reply to 8665.243
Hi Tudor, you could make a post here in the forum and then link to the forum thread. Github is a good idea too though.
8665.245
rectangle interactive
the idea is to combines all rectangles under one shortcut and switch between them from hotkeys
q rect
w rect center
e rect 3pt
r - will be added - http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.164 -> rect with 3ptcenter ~ another way to grow new rectangles
script is unfinished
- Tudor -
8665.246 In reply to 8665.245
Hi Tudor.
Only one rectangle ;-)
EDITED: 30 Sep 2020 by WN
Size: 26.9 KB, Downloaded: 73 times, Dimensions: 276x245px
8665.247
looks a like a runtime error, I dont have it !
it's about moi version or smt else not related to the script
or it might ask for html .. that I havent work on, try to add if it works
EDITED: 30 Sep 2020 by CEMORTAN_TUDOR
8665.248 In reply to 8665.247
Hi Tudor.
Ok!
Show messages:  1-8  …  169-188  189-208  209-228  229-248  249-268  269-288  289-308  …  369-372
